Heavylift variable pitch quadcopter
It is my first drone
Motor to motor distance : 140 cm
Rotor diameter:70 cm
Maximum size:210 cm
Weight: 1.6 kg ( esc, motors and wires) without batteries
Motors are 4 pcs http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9021
White gears are from HK450 class helicopter with one way bearing for autorotation
esc 4 pcs http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11430
Tested in the house tied to that piece couch. At full thrust it tried to lift the couch which has over 14 kg
I tried to use Arduino to level the drone but using just the accelerometer is quite hard. I'm trying now using accelerometer wii motion plus gyro combo
I filtered the data from the accelerometer using a simple low pass filter. I'm currently trying to understand Kalman filter.
I tested it outside but it failed to level the drone and have a little crash. The damage was only visible on the pipes. So I bought a new set
Is the accelerometer sufficient for the job?
I also bought a lot of sensors (sonar, barometric sensor with 9 cm resolution, gps, magnetometer 1 axis, gyro, and KKcopter controller board to replace my arduino)
  • can you get the ratings of the motors, and then plug all of your variables into the formula found here to get an idea of how much this quad can lift
    Helicopter Aerodynamics, calculating thrust loading, disk loading, power loading
  • 3690878975?profile=original
    3692241782?profile=original
  • Accelerometer is not enought to stabilize quadrotor. Main reason is that because of vibration.
    And also accelerometer can't stabilize yaw.
