Hello.
I am trying to understand ardupilot position and attitude control for a quadcopter by reading code.
1. I was trying to understand attitude control description from the code but I don't understand the     difference between target attitude and desired attitude. Can some one explain the difference please. Below is the description:
// The attitude controller works around the concept of the desired attitude, target attitude
// and measured attitude. The desired attitude is the attitude input into the attitude controller
// that expresses where the higher level code would like the aircraft to move to. The target attitude is moved
// to the desired attitude with jerk, acceleration, and velocity limits. The target angular velocities are fed
// directly into the rate controllers. The angular error between the measured attitude and the target attitude is
// fed into the angle controller and the output of the angle controller summed at the input of the rate controllers.
// By feeding the target angular velocity directly into the rate controllers the measured and target attitudes
// remain very close together.
2. Also they always mention feedforwarding velocity, angular velocity. Does anyone know what that means?
Thanks a lot.
