Need some help with these logs
This will be my first post in the forums so please be gentle on me ;)
I recently built a hexacopter and have been tuning it back and forth, its been flying ok but as with most dji F550 users theres a bit of compass interference from motors, esc, wiring and the battery so I tried a few mounting places for the APM2.5 but never really got rid of the "toilet bowl" effect.
So my last addition was a landing gear with a GoPro mount in the front and a battery cage on the back, as usual with a hardware change i did compassmot setup and headed out for a spin expecting some performance improvement sins compassmot now only gave me about 90% interference (only as compared to 215% before) .
Results:
- Still experiencing "toilet bowling" and if i'm not mistaken its gotten worse. (Maybe duo to a bigger load)
- A sudden drop/total motor shutoff lasting approximately for 1 second.
- Over all flight capability is good as far as I can tell.
After checking the motors and esc:s for unhealthy heat (witch there was none) i decided to do another try and se if there was more glitches but it did turn out alright.
So to the fun part, log analyzing :)
Of my two testflights i gathered some scary data, one being a sudden gps RelAlt read of 1660 meters for no apparent reason. (compensating for that might have required a total stop of motors?)
Even though RelAlt skyrocketed the gps:Alt was solid at the time being.
From the second flight a few weird 0 readings, CURR:Volt and CURR:vcc, CURR:Curr and CURR:CurrTot
My setup is:
APM2.5 with 3DR power module and a Ublox gps.
DJI F550 flamewel, stock DJI motors and esc:s with 1038(the new ones) propps running on 3S.
Landinggear with a GoPro mount.
I appreciate any help regarding my setup and/or the logs i provided.
2013-08-11 15-33 1.log
2013-08-11 15-35 2.log
