I am facing some problem when using mavproxy. Details of my problem are mentioned below. This is the command that I wrote at windows command prompt:
C:\Python27\MAVProxy-1.3.3\MAVProxy\mavproxy.py --master="com9" --baudrate 57600 --out 192.168.1.100:60000 --out 127.0.0.1:8000
The python application which is listen at 8000 port is works fine and the GCS which is connected using UDP Protocol is also works fine but after some time approx 5 to 10 minutes dos prompt shows error "No link" . I am stuck at here. Kindly help.
Thanks,
B4BUDDY
