Im revisitng a 400-class quad a/p build I have.
I'm wondering if using a PDB rated at 80A total is ok to use on this build or should i go direct wiring harness from the lipo to 30A ESCs?
They are spinning 10" props on 900kv T-Motors which use 13.4A each at full voltage (53.6A total). I use 3S lipos typically 5200mah 30-35C. I've also got a gimbal and fpv components onboard running off the PDB which I doubt take up much amps. This is for an a/p slow flying build so I wouldn't be punching it for normal flight.
Any advice appreciated - PDB or go normal wiring harness?
