Pixhawk autopilot problems.. Help?
Hi all,
I’m a complete novice and have been attempting to hook up a PixHawk to HobbyKing’s Bixler 2.
First test flights went well in MANUAL/STABILIZE and FBWA modes, but we had an issue when AUTO mode was selected. We’d loaded on waypoints via Mission Planner, double checked them, and attempted to set the craft to follow them once in the air, however the Bixler didn’t gain altitude or head towards its waypoint and required manual take over to bring it back.
N.B. there’s NO pitot tube on board, although all air speed parameters have been disabled.
Why is the craft not following its designated path once switched into AUTO mode? It seemingly stays in FBWA mode. Have we missed a parameter, perhaps one which requires a pitot tube?
I’ve attached the two flight logs from the tests.
Any ideas?
64.BIN
67.BIN
  • "Whatever you do, do not post logs, much funnier to have people guessing wildly"
    • I attached the logs to the original post as .bin files. Had never heard of Droneshare before
    Have you tuned it for your aircraft? Instructions are here. You probably just need to turn up the Navigation gaim
    • Will have a proper look at tuning tomorrow. However, these seem like solutions to poor flight in auto mode but where auto mode still works to a certain extent; our trouble was that auto, even though enabled, didn't kick in at all (correct me if I'm wrong!)
