Hi all,
This is my 2nd week with my first F450 running my first Pixhawk(APM). It fall down from about 20ft at Loiter mode and luckily only with 1 prop was broken ,other components seem to be ok
Pixhawk 3.2.1
Motor: sunnysky 2212-980kv
Prop: 1047
Battery: 2200mah 3s / 2200mah 3s x 2
Wind: Low, can't feel much at ground level
- Right before the crash, I run autotune and my bird was pretty smooth by carrying 1 x 2200mah 3s battery
- Then I loaded 2 x 2200mah 3s battery to try to max the airtime. However, it roll like a boat about 20ft Loiter mode after flying 5mins and the quad just can't kept itself steady and I didn't change to other mode as I wish miracle would happen.
After reviewing the logs, it seems pretty obvious that it was due to mechanic failure for Roll vs DesRoll
If somebody can give me a hint based on the log file i attach to this thread i will be very grateful.
My Questions:
1. Is that ok to carry 2 pack of 2200mah battery by using the autotuned PID when it was carry 1 pack of battery?
2. Should I use 9" prop or 10" is also fine?
3. What would be the possible cause? broken prop in the air? ESC out of sync? motor?
Thank you in advance...
Before_autotune.zip
crash.zip
  • MR60
    3701970368?profile=originalYour Zacc was ok until the mechanical failure and went haywire precisely at the same moment your Roll vs DRoll did not match anymore. This confirms I think a mechnical failure or your pixhawk not correctly fixed to the frame.
    • Hi Hugues,
      Many thanks for your analysis. My pixhawk was mounted on this vibration board and it was indeed the second time I found the upper deck detached from the bottom deck. Perhaps I should fix the board before I fly again, many thanks!
      飞控板 减震器 APM2.5 2.6 KK MWC 海盗 玉兔飞控通用型减震板
      • on a second thought, I did able to find the blue rubber next to where my F450 dropped. So can I assume the anti-vibratio board fall apart when it hit the ground?
