AC3.2 on a 3DR 2014 DIY Quad with Pixhwak.
I have occasionally seen these and usually unplugging and plugging in the battery fixes things. However, today it would not clear and I could not get off the ground. I had done a short test flight earlier without issues in a different location. The compass direction in the telemetry seemed steady, but was indicating a different direction each time I rebooted.
I have recently change the configuration from Spektrum satellite to OrangeRX R800X and added a Fatshark 25mW 5.8GHZ transmitter. Are either of these likely to interfere with the compass? Or is it hardware failure?
Thanks for any info.
andy
I'm having the same problem. Even moving the vehicle too much around confuses the compass easily. A reboot clears it away. Is there a way to reboot compass when pixhawk is on?
Just to update anyone who googles across this. My findings are:
- Compass not healthy does not mean hardware failure, it just means the sensor is overloaded.
- Calibrating outdoors away from all possible sources of interference makes a huge difference.
Thanks for the suggestion. Obviously the number of satellites picked up by the GPS will have no bearing on the compass performance. I don't want to disarm the check as a bad compass has potentially disastrous consequences.
An update on this. I recalibrated the compass very carefully without issue (selected Pixhawk in APMPlanner2). Calibration found two compasses - internal and external I assume - and the IDs were as documented in https://github.com/diydrones/ardupilot/issues/1355 - i.e. both had ID's, compass 2 was NOT -1. Is this correct? The compass heading in APM is correct and responds quickly to movement. Applied power and same result "Compass not healthy". Tried again and got "Compasses inconsistent".
So here's a weird thing. I apply power with the copter not moving (obviously). If I then rotate the copter a little so that the heading viewed in APMPlanner2 moves the error goes away! This sounds more like a software than hardware issue to me, but knowing zero about the firmware I of course could be completely wrong. If a compass is faulty, how can I tell which one. How can I tell whether the calibration is reasonable?
Thanks for any info/ideas
andy
I'm using the 3DR uBlox compass/GPS kit as well.
