  • Not enough information. You need to know your maximum amp draw.
      There is no minimum C rating for a current sink, just a max Amp that the power module can take. There's no link between them. A 5C 2 cell battery can blow the PM, but only if you connect enough components that pull that amount of amperage.
    The power module can handle up to 2.25A.
    This is not related to C rating which is a function of the number of cells and the current they can supply. Personally i find it very confusing. Two batteries with the same 10C rating will deliver 30A for a 3 cell versus 20A for a 2 cell.
