Hi
While analyzing my logs I noticed that there is a quite big difference between MixAlt and GPSAlt. Is this normal or can it affect the performance of my flights? I always had a wierd problem with my platform were it sometimes wants to "kill itself" with flying into the dirt.
GPS: 29785500, 1, 10, 59.6473850, 17.6280900, 0, 128.2500, 23.0300, 0.1000, 130.2300
ATT: 346, 1516, 11337
CTUN:0.00,24.84,3.46,0.00,20.00,15.16,0.00,0.00,-1.42,
NTUN: 113.3700, 124, 214.0700, 214.0700, 96.8100, 0.0000, 0.0000,
GPS: 30443500, 1, 8, 59.6471020, 17.6283860, 0, 124.9800, 49.3800, 0.0000, 199.9900
ATT: 2290, -3352, 4626
CTUN:0.00,-6.67,22.90,0.00,-11.78,-33.52,0.00,0.00,-3.09,
NTUN: 46.2600, 125, 234.8200, 234.8200, 100.0000, 0.0000, 0.0000,
Thankful for input. Will let me relax a bit during my auto flights since I always for the finger on the manual-trigger/switch.
Kind regards,
Jesper
Hi again
I noticed that the first couple 100 lines in the log shows a predefined GPS altitude of 137 meters. This is before I get a GPS lock.
GPS: 29689583, 0, 6, 0.0000000, 0.0000000, 0, 0.0000, 137.0000, 0.0000, 0.0000
ATT: 37, 30, 21
CTUN:0.00,0.00,0.37,0.00,0.00,0.30,0.00,0.00,0.02,
NTUN: 0.2100, 0, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000,
Just when I get GPS lock both MixAlt and GPSAlt show about the same,
GPS: 29722500, 1, 8, 59.6464580, 17.6274470, 0, 126.1400, 124.9300, 0.0100, 355.3300
ATT: -48, -452, 34283
CTUN:0.00,0.00,-0.48,0.00,0.00,-4.52,0.00,0.00,0.16,
NTUN: -312.5300, 1, 108.4300, 108.4300, -1.1100, 0.0000, 0.0000,
But then a couple of seconds later when I get GPS lock MixAlt is way off (I live approx 35 meters above sea level).
GPS: 29736750, 1, 9, 59.6473850, 17.6280210, 0, 126.0600, 34.7000, 0.0900, 242.6500
ATT: -266, -51, 33029
CTUN:0.00,0.00,-2.66,0.00,0.00,-0.51,0.00,0.00,0.69,
NTUN: -325.0700, 121, 210.9700, 210.9700, -1.0600, 0.0000, 0.0000,
Any ideas?
What is the maximum time Arduplane can log? Yesterday my plane got caught in a tree and it took four hours to get it down - using a chainsaw.
When loading the logs I got "Bad log number" from 2 files och the working log only contained 37 minutes. All including the part where the tree fell to the ground. Approx -1.8 m/s :)
Flight including tree time = 4 hours
Only got 37 minutes instead
Hmm. Last couple of flights I have not even been able to download the logs. I cleared everything before flight to be sure.Get this text when trying to "Download All Logs" in Mission Planner.
Log number 1,   start page 92,    end page 52
Note that end page is lower than start page. Does not seems right.
