i build a quadcopter and it doesnt want to lift off, im using a power supply to produce enough current so quadcopter could fly, when i go full throttle my quad just keep spining to one side i try to move the PID'S but i wasnt successful, im not sure if thats the problem or if its something else, if any body has any suggestion i would really apreciate thank you.
Calibrate ESC's. Tie the thing down to at least four pounds worth of stuff and see if it can lift upward while restrained. You can also remove the props and make sure motor rotation is appropriate, ESC's are calibrated, and controls are responding as expected.
