Hello!
I am building my first quadcopter with the parts listed below that i had recommended.
Can i only buy the arducopter and be done with it or do i need anything else?
do i need to replace the sender\reciever to more channels? to have use for the auto hold etc?
do i need bigger motors? Anything in the list not needed when buying arducopter?
Any help and tips would be much appreciated=)
| Item | Description | ||
| Turnigy nano-tech 2650mah 3S 35~70C Lipo Pack $22.99 Email me when stock arrives |
| LED Red, Green, Blue (RGB) Strip 25cm w/Flying Lead $2.49 Email me when stock arrives |
| Hobbyking i86 Multi-Rotor Control Board $21.99 Email me when stock arrives |
| Hobbyking KK2.0 Multi-rotor LCD Flight Control Board $29.99 Email me when stock arrives |
| Hobby King 2.4Ghz 4Ch Tx & Rx V2 (Mode 2) $22.99 Email me when stock arrives |
| Slow Fly Electric Prop 1045R SF (4 pc - Green Right Hand Rotation) $3.07 Email me when stock arrives |
| NTM Prop Drive 28-26 1350KV / 310W $15.99 Email me when stock arrives |
| Turnigy AE-25A Brushless ESC $10.58 Email me when stock arrives |
| Hobbyking X666 Glass Fiber Quadcopter Frame 666mm $17.03 Email me when stock arrives |
Tags: multicopter, needed, new, parts
Permalink Reply by Thomas Gabrielsen on January 6, 2013 at 2:20pm
Where are theese switches? Or where\how do i get them?=) Yes im a newbie
Permalink Reply by Luke Olson on January 7, 2013 at 8:08am ArduCopter runs on the APM, not the Hobby King control board listed in your original post. If you want ArduCopter features like loiter you'll need the APM. The kits from 3D Robotics are a great starting place.
http://store.diydrones.com/3DR_ArduCopter_Quad_C_Full_flight_electr...
That kit comes with the APM and everything else you need (add radio, battery, charger). If you want to use the APM on a different frame you can get the APM by itself.
http://store.diydrones.com/APM_2_5_Assembled_p/br-apmpwrkt.htm
Permalink Reply by Thomas Gabrielsen on January 7, 2013 at 6:45am Please if there are anything else i need let me know, cables etc, i need everything ready to build and fly. I can not
order until im sure about all i need
Permalink Reply by Drone Savant on January 7, 2013 at 6:56am If you get uncomfortable you can always order an assembled and tested ArduCopter quad from JDrones - http://store.jdrones.com/product_p/acq11arf.htm or UDrones - http://www.udrones.com/product_p/acrtf2.htm
(those switches you mentioned come from your Radio gear... aka Turnigy 9X or Spektrum DX7 as examples. They are often your "flaps" or "gear" switches (sometimes used simultaneously) in order to tiggle the modes.
185 members
51 members
686 members
87 members
Powered by
