I'm having issues getting my quadcopter working properly. All my connections are tight. I'm using turnigy plush 18A esc's. The board I'm using is a hobby king Kk board. the motors are turnigy sk 2826's. I've programmed each of the esc's for Ni-XX. The rest of the setting I left as default. The problem I'm having is on motor spin up. The motors cut-out or over rev unexpectedly. I had one case where I had the throttle revving fine at a low rpm, quad still resting on the ground. All of a sudden quick throttle rev and the quad flipped over. I wasn't doing anything. It's almost like interference. I've looked all over the web for ideas but really haven't had much luck. Hopefully someone can help me out. Thanks!
You need SimonK firmware and calibrate your ESC's . Check into what SimonK does as far as cutoff and see if that description fits.
