I've seen a bunch of Tricopter projects along with all the usual Quadcoptes. Can anybody explain what the advantages of a Tricopter are? I can see that it's one less motor/ESC, along with the weight that comes with that, but that's at the cost of requiring a mechanical tilting mechanism with all the accompanying complexity/vulnerability, isn't it?
The tricopter ( im talking about the rcgroups/signguy-style)
pros:
its simple, non expensive($150-200), and analogue stabilized with the gyros(no firmware/programming), collapsible/easy transport, I build mine of wood (pine) so there is easy to get materials, its possible to film between the arms, no need for CW-CCW props.
easy to repair (http://www.youtube.com/watch?v=Vb3HOG9LHTg)
Cons:
-more strain on each motor and propeller( the bearings takes a lot more beating)
-not that acrobatic as a quad can be.
-you have a mechanical part on the yaw... its easy to make, works great, but is vulnerable and weigh a lot on the tip of the arm.
pros:
Cons:
L-P Lorentzen
http://vimeo.com/user2000942/videos
