Hi, I just wanted to give update on an issue I had with the Quanum FPV goggles.
The problem was that after installing the goggles whenever I powered up the quad(throttle > 30%) I lost the video signal almost completely.
I did all kinds of tests, stripped all components from the quad, read about low pass filters. changed batteries.... no luck
I took me a long time to find it but solution was very simple tx
to gordini8 at http://www.rcgroups.com/forums/showthread.php?t=2418256
The Audio cable on the Quanum should not be used!
problem solved...
hugo
