Razor 9DOF + GPS + arduino serial com with NewSoftSerial
Hello,
  I am trying to combine a Razor9dof, a GPS (ls20031) to an arduino (duemi).
I have configured the Razor with the ftdi cable. Works fine. Also connected to the arduino, on pin0, works fine.
Here is the code:
void setup() {
  Serial.begin(57600);
void loop() {
  if (Serial.available()) {
    Serial.print(Serial.read(), BYTE);
However, using NewSoftSerial library doesnot work. I get lots of giberish as output.
My code is:
#include <NewSoftSerial.h>
NewSoftSerial nss (4,5);
void setup() {
  Serial.begin(115200);
  nss.begin(57600);
void loop() {
  if(nss.available()) {
    Serial.print(nss.read(),BYTE);
I have the gps connected on pin2 and the razor on pin4. Using the above code (and changing pin 4,5 to 2,3); I get the nmea sentences alright.
Any ideas on why serial on pin0 works fine, but NewSoftSerial does not?
Nicolas
  • Hey,
    Can you show me how you build up the program further if you want to use for example the acceleration measuring? I don’t know how to do it.
    Thanks in advance
    Johan
  • new problem is with the gps; I don't get the whole sentences through newsoftserial. Through serial pin0, everything is fine.
    Is newsoftserial the way to go?
    Nico
  • ok, dropping the razor baud rate to 38400 made it work.
