Realtime video stabilization
I want to record video downlink with a video digitiser connected to USB port.Does anybody know a freeware (or opensource) video stabilization software that runs on a laptop computer and process digitized video for stabilization ?Or do you know if there is an affordable hardware solution for this?Thx.Miem
  • There is a project http://www.navlab.net/, which has an example of post-processing a 'line scanner' image capture on their front page under 'Aerial Imaging'.
    Maybe this can be used for correcting video as well as stills, you would need to feed/record your accelerometer data in real time.
    Depending on the size of you UAV you might be able to mount a damping system onto the camera, or use a stablised lens system.
    Mungewell.
  • I know its a bit of a delay for this reply but its probably something many people wish to do for their FPV creations.
    Not sure off hand for live video, but if you want to "fix it in post" http://www.sundancemediagroup.com/articles/deshaker_guide.htm in conjunction with http://www.virtualdub.org/
    Other than that is getting a camera with OIS or DIS built into it.
    Hope that helps.
