hi,
i'm working on a project which aims to bridge the gap between simulink high level code
and arducopter low level code.
i bridge the gap by expanding the simulink library with block set(kind of toolbox)  which represent arducoper components, such as motors,remote control etc..
and by creating adapter code which help c code, which generated by simulink, to communicate
with ardupilot original code ,with the help of some library functions.
because this kind of system is not a regular system, so regular unit tests will not work in.
i'm looking for suggestions how could i test the blocks which the user creates with simulink.
i would like to build kind of automatic test suit which test the code  virtually with sitl and physically  test the code on arducopter itself , to make sure this blocks work as expected.
where should i begin ? how do i retrieve information from arducopter to simulink?
i will appreciate any help.
thanks,
hanan
