Having successfully reflashed the escs ( much smoother by the way) the original problem which put me on this path remains. Basically, As i lift off, the quad spins and as soon as it makes one or two hops, it seems to jar its brain and then flies in a directed and far more oriented manner that resembles controllable. What could this be?
Setup: Stock everything with 4-12 x 3.8
APM 2
Also I seem to get caught in a loop with the newer planner when trying to graph, as the connection demands the mavlink version 1 despite it being the 1.0 version already and cannot create a graph. Any thoughts?
tLogs are attached if thats helpful
TIA Bart
Permalink Reply by Bart Mowrey on June 25, 2012 at 12:55am I have, and down to 5 decimal places.
Also have gone over the posts here like the freakin zapruder film to get past the learning curve. There are consistantly other issues as well, like never a smooth liftoff unless i really throttle it up at the same time as its spinning. Enough to drive a guy batty. IM sure its something Im not hip to in the setup though as a newb i cant be sure of whats a normal behaviour or some totally abnormal thing. I can get a little ways if i throw it into loiter mode, but otherwise i cant seem to keep it level or hovering real well or consistantly
My guess is that your frame/motors/something is bent, causing a yaw tendency, and it takes a bit of time for the controller to figure it out. But it's hard to say for sure, I'd need to see the flash log with PID enabled and set to the yaw controller.
Permalink Reply by Bart Mowrey on June 25, 2012 at 9:53am Thats entirely possible i suppose. Fwiw the behaviour was there from the first liftoff attempt, and visually everything appears to be square, so it cant be off by much. I actually rebuilt the motor mounts from the get-go as using only 2 screws bent the motor casing which in turn caused shaft binding which was obviously going to create problems.
Permalink Reply by Bart Mowrey on June 25, 2012 at 12:51pm Pardon the stench of newbness, but how do i set up the APM to log this? I can t locate anything in the planner to do so. ( this is just hand flying missions so far)
i am using the newest rev of both firmware and planner with the mavlink 1.0
You need to go into the CLI to modify what you are logging. So you want to turn PID logging on, and make sure ATT is on as well.
Then, to actually log the yaw PID data, you need to set Ch6 tuning to Yaw_Rate_P. Don't actually change your Rate P value.... just need to set it to that so that it will log. That's how the PID logging works.
So, that's about it.
Permalink Reply by Bart Mowrey on June 25, 2012 at 2:30pm awesome- thanks so much- info is a bit tough to find around here. ill post up a log when i can actually fly it again- busted props and whatnot from the repeated hard landings and abortive takoffs with a full gainer and triple lindy.
Permalink Reply by Bart Mowrey on June 26, 2012 at 1:02am Potentially stupid question: how long should the process of downloading logs take? Im starting to think theres something seriously wrong with this APM as its taking hours to download logs, and spits out garbage in the CLI..
MOF here's output from the CLI. ( these are ALL of the characters... )
NTER3 tmes or LI
opter V2.6] U/VWXYZ[!\]L^rq_
`abc*`deGnfy
hw Invalid command, type 'help' ArduCopter V2.6] Lsogs Inalid ommad, tpe 'elp' ArduopterV2.6 !}a/BBB_+B~BBCB,)B|BgBDB:EBB_B( M Invalid comand, type 'elp' AduCoter 2.6 g .-P @^~p<BN#2L {!"]#E#$S%(-&' nvlid comand, ype 'elp' rduCoter V2.] UBXVBBMFXYZ[!\]L^rq_`abc*`d nvalid ommand, tye 'hlp' ArduCoter V.6]Ls!}a/B|ou=KC3&M/Q(E{!_Hhv%fBBW M nvalid cmmand, tpe 'elp' rduopte V2.] g .-P @^~p<BN#2L {!"]#E#$S%(-&' 2 rvaid cmman, tye 'elp' rduCopterV2.6 Ls!}a/B|ou=KC3&M/Q(E{!_Hhv%f+zx nvalid ommand, tye 'hlp' ArduCpterV2.6 g .-P @^~p<BN#2L {!"]#E#$S%(-&'
Are random characters prints a normal occurance or am i looking at a screwy APM? Again, newb to the microcontroller arena here
Thanks for your help!
Bart
Yeesh, I dunno, but I don't thing you should be seeing that. Are you downloading the logs through the CLI, or are you using the GUI in MP? I use the GUI, it's easy, and I never see anything like that. It definitely shouldn't take "hours". Maybe 15 minutes or something like that.
You might need to try completely erasing the flash and trying again.
Permalink Reply by Bart Mowrey on June 26, 2012 at 10:35am im using the planner GUI and i wasnt overstating the time for effect, and had connected and reconnected several times. THis morning however it seems to have straightened itself out somehow and things appear to be working properly ATM. i realize the PID logging hasnt been enabled as you requested, but if you graph the yaw you can see whats going on.not sure which files are really needed so im posting all three. Ill do a real one with PIDs enabled in the next few days, if your offer still stands.
Bart
Yeah, there's not much I can get from that, I need the PID. I will say that it appears maybe you have some excessive vibration or magfield or something.
Permalink Reply by Bart Mowrey on June 26, 2012 at 12:38pm I did have an excessive vibration and magfield in college, but some doxycyclene cleared it right up. THanks for looking- im really thinking theres more going on here than my ignorance
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1277 members
24 members
183 members
246 members
179 members
Powered by
