Hi.
I want to know how to select motors for my quadcopter. I tried ecalc but couldn't do it. and I want specific calculations for it.
Also how to calculate thrust and lift force produced by rotor? my drone specifications are-
motor - 1200 KV brushless
propeller, 10*4.5 inch
battery- 11.1 V
approx weight of drone including all parts is 1000 gm.
As per my knowledge,
rpm = KV * V = 1200 * 11.1
= 13320 (no load)
But i guess, weight of the drone should be considered.
with that setup you motor is not correct you need 700kv 900kv Motor 3S to 4S battery. standard setup 8- 10 inch props 450 size craft.
