I am thinking sending APM power glider to near space by balloon and return home. Anyone already made it?
Tags:
Permalink Reply by Emery c. Chandler on December 27, 2012 at 5:53pm I have not done that yet, and you are probably the first to do it conrolled. when you make this the payload of the balloon must be under 4 pounds (regs may very pending nation, but 4 pounds or less is good) add two strips of foil for radar check, the tail or midsection should have foil wrapped around it for he same purpose. this is a safety feater (the foil) which allows for radar stations to alert aircraft of an unknown presence bearing mass, if you have a airport in the 60 mile radius alert them and seek clearance (again percautionary). cant wait to hear your results, hope it goes by well and safe, love a video!
Permalink Reply by Eric on January 1, 2013 at 12:39pm This is an idea I was thinking about also, its nice to see that someone else is attempting to do the same. I actually wanted to film the whole thing via a cam on the uav/glider.
I've been doing a bit of research which led me here.
The link you provided is exactly what I'm wanting to do. I'm still at the drawing board to see what would be best for this type of project.
I've been trying to answer a few questions, not sure if they will come into play, but they still seem to be variables in this project. Most of which seem to be focused around higher altitudes.
1.) Tracking this on its accent. Determining a "detach" point/altitude.
2.) High alt winds, will this blow the glider off course? If so, how easy would it be to get back to a certain waypoint.(battery life, enough power to get to waypoint x)
3.) Will higher altitudes and temp affect battery life(assuming it will be up there for a minute or two).
4.) Will gps be effective at higher altitudes?
5.)Is a glider the best solution? Weight wise?
6.)would audropilot be a good solution for this type of project?
Like i said I'm still in the research and development stages of this. I hope to have something together soon for flight.
Cheers,
Eric
Permalink Reply by Emery c. Chandler on January 1, 2013 at 2:32pm Eric- im into the hig altitude stuff as well, i have some answers or insight on some question
2) may not blow it off course but could pose issues loosing altitude or the integrity of the aircraft
3) temp does affect most battieries, it helps them keep their charge it maybe safe to say it gives it longer life, try testing the battery you wish to use in a freezer for certain periodes of time
5) gliders are probably the best solution in this casee
but one last thing i did not mention- at the higher altitudes their is a lot of radio interference, your camera may even pick up transmissions something to think about, I know the american AF did an experiment try looking it up to see if someone posted results or issues. cheers*
Permalink Reply by Eric on January 1, 2013 at 11:03pm So it looks like there is a lot of regulations with the FAA regarding UAV's or "UAS" - Unmanned Aircraft Systems.
Heres the link to the FAA's site for the above:
http://www.faa.gov/about/initiatives/uas/reg/
Eric
Permalink Reply by Andy on January 2, 2013 at 1:37am 4.) use a uBlox and you're save up to 50'000m (i've tested that :))
6.) YES! It works very well just change some code so you can release the glider from the balloon.
Andy
Permalink Reply by Eric on January 2, 2013 at 8:25pm Andy, thanks for the response.
I'm going to try to move forward with this project and do lower altitude testing to stay within FAA regs. I'm not going to totally put high altitude launches out of the question just yet.
eric
Permalink Reply by Larry Grater on January 3, 2013 at 10:57pm
Permalink Reply by Cameron Jones on March 16, 2013 at 11:20am
Permalink Reply by Michael on March 22, 2013 at 6:41pm I know I'm asking late, but did you do the project yet? If so, how did the APM perform at high altitude?
Permalink Reply by Larry Grater on March 22, 2013 at 7:32pm Last weekend NTNS-3 hit its target LZ at 9k AGL from a drop at 48k. Video to follow.
Permalink Reply by Larry Grater on April 15, 2013 at 4:24pm The video below link below is interesting because the RC Explorer guys talk about how hard this is and that it took 4 tries to get satisfactory results. Well, it is hard.
Here's a link to the post flight video from North Texas Near Space 3 and the post flight report. The goals of the report were to report general information on results + root cause and corrective actions for any anomalies. Hardware for the next mission is on the bench.
Larry G
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.1299 members
48 members
693 members
51 members
249 members
Powered by
