Sonar Data
Where can I see the output of the sonar? I want to check and make sure it is working correctly.
  • Is there anyway to display this information on the OSD in flight?
  • You need to go into CLI and type "test" and then "sonar".  It will then output the sonar readings in centimetres.
    Otherwise, download the .log and you'll find both Baro and Sonar altitude in the CTUN data.
