Sonar Success!
I have had many sonar probs over the various releases and now I have gotten it working beautifully. I have the MB1200 (XL-EZ0) sensor, currently on 2.0.37 on stock AC frame. Initially I had the sonar hung with spacers 2" under the main body under one ESC. I just used 3 unshielded hookup wires. The results were not pretty-  (red=sonar   green=throttle)
3690880058?profile=original
Then I put the plastic ring from the sonar mount kit on .5” spacers so it was even with the sensor face. Data got a lot better-
 3690880103?profile=original
Then I installed shielded wire (shield + 2 wire) and mounted it out like this- (Great use for old leg!)
 3690879972?profile=original3690880070?profile=original
And the data became –
3690880112?profile=original
 This flew perfectly – easy to see as it crossed from cement to lawn and to curved cement without missing a beat. Height tracked the ground and the motors stayed very smooth.
We are getting closer everyday.  I still wonder – is it possible to hack the software to enable alt hold while in simple mode or are those very separate functions that can’t run simultaneously?
    That looks great. We should recommend the shielded cable in the Wiki.
    Jason
