This is what happens when the yaw tilt mechanism of the tricopter fails, or at least this is what I think that happened...
I don't know how but the linkage rod of the yaw tilt mechanism came off from the servo arm. I need pliers to do that! I can't do it with my bare hands. The servo noise is from the camera tilt.
Firmware: ArduCopter 2.0.55
Tags: arducopter, crash, fpv, gopro, log, tricopter
Permalink Reply by Ellison Chan on December 13, 2011 at 12:31pm More likely servo failure. I think the control arm popped off when the prop/tail hit the ground.
Permalink Reply by Marc Puig Pasarrius on December 13, 2011 at 12:46pm It's strange... I've tested the servo and it's ok.
Permalink Reply by Ellison Chan on December 13, 2011 at 12:50pm Did you test it under load? But, like you said, it takes a lot of force to get the servo arm to just pop out.
Permalink Reply by Marc Puig Pasarrius on December 13, 2011 at 1:01pm No, but I have a 3A UBEC (max 5A) and it usually consumes less than 1A.
Wow, those Go Pros are rock solid aren't they!
Permalink Reply by Marc Puig Pasarrius on December 13, 2011 at 1:31pm Yes! They are. After a lot of crashes I've broken only one GoPro and it still works partially :)
I noticed after all that it did manage to correct itself somehow and land on its belly. Really amazing crash.
1288 members
57 members
680 members
87 members
Powered by
