Teach you how to DIY a quadcopter
Many people don’t know what should they buy for DIY a quadcopter? And how to DIY a quadcopter which can flight longer and higher? Now I will tell you how to DIY a quadcopter like this .
Next I will tech you how to DIY a large quadcopter, what do you need? How to test and assemble the system? The first step: you must know the Materials and its usage.
Frame:
Usage: Provide basic support and bearing variety of equipment, it need high strength and light weight,
Mini quadcopter: Light weight, low load requirements, PCB can meet the demand,
Large quadcopter: High load requirements, up to several kilograms, Commonly used nylon, carbon fiber, they are high-strength low-weight materials;
Motors:
Usage: spin the propellers,
Mini quadcopter: Brush motor, it is very light,
Large quadcopter: Brushless motor, to provide more lift;
Electronic Speed Control:
Usage: tells the motors how fast to spin at any given time
Mini quadcopter: Don’t need, Motor based on the voltage controlled power,voltage output control  by PWM,
Large quadcopter: Brushless motors have a special sequence control, and need large current output, you can buy a brand Electronic Speed Control;
Propellers:
Usage: A quadcopter has four propellers, two normal propellers that spin counter-clockwise, and two pusher propellers that spin clockwise.
Mini quadcopter: Small propellers
Large quadcopter: Larger and Thicker propellers, To provide more lift;
Battery:
Usage: Power source, use lipo batteries
Mini quadcopter: Voltage: 3.7v, capacity: hundreds mAh, Flight time: 5-8 mins,
Large quadcopter: Voltage: 11.1V, you can use 3 3.7v lipo battery in Series or buy a 3s lipo battery.
Capacity: Thousands mAh, Flight time: 8-15 mins;
Battery Charger:
Usage: To charge the lipo batteries
Mini quadcopter: Balance charger
Large quadcopter: Balance charger
Main Control Board:
Usage: Control the flight condition
Mini quadcopter: PCB is its main control board
Large quadcopter: Dedicated main Control Board, with its Own stability program; External inputs and outputs used to dock
Remote control:
Usage: To control your quadcopter
 Mini quadcopter: Bluetooth:  control by your phone, 2.4G radio: Dedicated remote control
Large quadcopter: 2.4G radio: Long distance control, Dedicated remote control
Auxiliary materials:
Usage: Used for splicing machines and fixtures equipment.
Large quadcopter: DIY a large quadcopter, you need: sillicone, heat-shrink tube, power distribution, screw, Battery voltage alarm and so on.
  • If there are no problems, you can test all the ESC and motors first, be sure everything are OK.
    3702332978?profile=original
    When you test the motors, you should test the max and min accelerator, and you should pay attention to the lost control signals , if signals lost, the motors must stop work(if you not do this, your drone maybe lost).
    3702332851?profile=original
    After motors control, I can begin to assembly, frame assembly is very simple;
    3702332863?profile=original
    Installed power distribution board
    3702333001?profile=original
    First turn on the power and flight control board, debug the rotation direction of the motor, keep up with crazyflie, Brushless motor change the motors direction, just exchange 2 of the 3 input signals.
    3702332885?profile=original
    Confirm it is Ok, fixed flight control board,
    3702333019?profile=original
    Propellers must use a screwdriver to tighten,
    3702333106?profile=original
    Complete assembly
    3702333040?profile=original
    Tie up all the lines.
    3702333080?profile=original
    Crazyflie flight control
    3702333163?profile=original
    Very larger Propeller,
    3702333128?profile=original
    Special apron
    3702333184?profile=original
    3702333255?profile=original
    Ok, this is my DIY quadcopter, what about it ?
  • These are my Materials:
    3702332321?profile=original
    Balance charger
    3702332451?profile=original
    3702332622?profile=original
    3S lipo battery
    3702332575?profile=original
    Propellers
    3702332342?profile=original
    The motors are the most expensive
    3702332645?profile=original
    ESC 3 black lines together are control lines, red with black is power line, they can supply power to the main control board, the red line and black hookup battery.
    3702332597?profile=original
    Brushless motor
    3702332768?profile=original
    3702332663?profile=original
    Frame with landing gear, 450mm, it is very large
    3702332717?profile=original
    Auxiliary materials, the power source in the right, the measurement of battery voltage alarm near to it.
    3702332738?profile=original
    Because I Debug the system of the large quadcopter by myself, I did not choose the finished fly control and remote control, I just DIY a crazyfile flight control board.
    This is the reason of why I choose crazyfile board:
    1 Open source systems,
    2 Reasonable system architecture, more complete help documentation and system documentation
    After you choose flight control program, we should make a plan about development. DIY a flight control program is not like buy a finished product, most finished products are very Reliable, you even don’t need test and fly it. But DIY a fly control can’t do it, you must test more carefully , so you can have a flight test, or it will be very dangerous, because the motor and the plane body are very heavy.
    First, we should test the motor part of the flight control, because I use the crazyfile, so the system can work well, but you need control the brushless motor by Electronic Speed Control, flight control use pwm to control ESC is not very simple, General ESC received signal range from 50Hz to 4xxHz , because the ESC received motor speed control signal not only get a Duty cycle. The actual use of the PPM signal, a simple point, in a pulse, 1ms high level on behalf of the lowest throttle, The throttle level of 2ms represents the maximum of the throttle, and the other time is low. The 0-100% of Throttle control is controlled by the high level 1ms-2ms pulse. So the signal at least 2ms cycle. 500Hz frequency.
    Second transformation the circuit board of crazyflie
    Pull out the power source and hook up the ESC 5V ouput port, docking the ESC PWM signal is a small board of Crazyflie, pad is very weak, so you must Fixed the lines carefully. I used two official PWN interfaces, it is easy welding, and the two others lead from the small expanded hole; then we need change the drive,
    3702332685?profile=original
    hookup a ESC to the power source board, Transformation the battery interfaces, hookup the flight control board power interface, Provide power to the flight control board. PWM signal input line leads out, docking the flight control board;
    3702332811?profile=original
    Use the crazyfile on PC, you can see many data information, I don’t have dedicated remote control, so I use my xbox one to control to push the accelerator and test the speed of the motors;
    3702332800?profile=original
