Distributor
Turnigy 9X Modes setup...
Thanks to Gordon for this posthttp://diydrones.com/profiles/blogs/mode-switch-setup-for-turnigy-1?xg_source=activity&id=705844%3ABlogPost%3A379114&page=3#commentsI am reposting my question in the Discussion as this Blog entry in now on page 3 (quite far to get an answer...)This got me running with configuring the TX to output mode switching values on CH6.Now the "problem" is that I was able to follow all instructions and in PWM test I get 1165, 1296, 1423, 1555, 1684 and 1815... so I taught I was all good....I am using 2.0.20 BETA but when I go into the CLI MODES setup flipping through all options it only register position 0 and 5 (both extremes...)what am I doing wrong??is the modes values changed on 2.0.X ?Help me out if you can... I would love to unlock the other flying modes. :)Thanks
  • hey guys, i attempted the mode switch setup last night, however i am a bit lost to know if i am actually doing anything as i see no evident values change when i flick the switch (throttle hold, back and forward) for instance. not sure if im explaining myself correct, only new to getting use to radios and the use of them but i do know how to follow steps :)
  • When I followed the post and used the pwm test on the cli I could clearly adjust the values as required on channel 6.
    The code uses channel 5 for mode changes
    That's as far as I got
    Rgrds
    Andrew
