Hi, I just received a new APM 2.5, so I decided to test in on a liitle Turnigy Micro-quad from HK.
All the standard configuration went fine, but I think I might need some (a lot of) PIDS tuning. The quad can't stabilize at all, as soon as it leaves the ground it oscillate very hardly and quickly in all directions, so I have to put it down quickly... the propeller directions are ok, and I don't think I have inverted some channel, it seems to be ok when testing with the quad in my hands - just have some doubt for the yaw but it seems worse if I invert this.
Would anyone have some param file to share, especially for the PIDS settings, or indicate what are the parameters I should look into ? - I tried to decrease slightly RATE_ROLL_P and RATE_PITCH_P as described in http://code.google.com/p/arducopter/wiki/AC2_Tweaks, but didn't help much...
For a tiny quad like that, turn your Rate Roll P values way down. Try decreasing in 25% increments.
Permalink Reply by Manu on November 23, 2012 at 2:00pm Thanks Chris. I realise that I might have been a bit shy on the decrease of this PID. I'll try that, together with the RATE_PITCH_P I presume. Tx
Permalink Reply by Andrew Radford on November 24, 2012 at 2:04am I have the micro hex - and found it is a real difficult one to tune. Rate_P has to be < 0.100 and Rate_D about 0.005 IIRC.
Try following the tuning guide, and if you can install SimonK firmware on the ESCs, or BLHeli if they aren't AVR.
Permalink Reply by Manu on November 26, 2012 at 7:21pm I got back to my small tiny micro-quad and managed to get to a reasonable balance with the following parameters:
RATE_P: 0.03
RATE_D: 0.005
I would have done some more fine tuning if my flying skills had been better... unfortunately a pretty hard landing on the side had the final word : chassis broken... :-(
Thanks all anyway, it's been a very useful tuning exercise in any case!
Cheers
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.203 members
24 members
207 members
58 members
1355 members
Powered by
