Upgraded to 1.2.58 and can no longer get logs
I just upgraded MP from 1.2.57 to 58 and now I can't get at the logs on the APM. It's showing no logs at all but I know there should be at least three and the usual log it generates when I have it hooked up via USB and I'm using MP.
The Log Download display does have some garbled characters and the following line:
"og 3,    start 630,   end 1123"
If I click on "Download all logs" I get a small screen that says "Nothing to Download"
I've restarted MP several times and power cycled the APM and no change.  This is something new with the upgrade.
Any ideas as to how I can get at the logs? There's some data I really need to see.
Thanks!
    this was to prevent accidential disconnectes while in the air.
    and on the px4, accidental reboots in the air.
  • New features are better than undocumented features. ;)
    -=Doug
  • Change in Mission Planner.  Now, when you go to Terminal mode you need to reboot the APM to actually get into terminal mode so all the options work.  Click the new Reboot button at the top left of the window.
