Just noticed after updating MP that when making a flight plan with the survey tool there is an option under the speed box that says "Use speed for this mission".
I know the speed of the craft can be adjusted but will this option 'hurry' all other parts of the mission?
Thanks,
  • It simply means that the speed entered in the field should be inserted into the flight plan as a do_set_speed command. If this is not check, the speed in the field is only used to calculate the flight time inside the survey tool.
