Hi!
I had a couple of HM-TRP modules laying around, and gave them a try. However my modules were 868Mhz ones. So I went through the code, and it seems that the bootloader supports 868Mhz, but the initialisation part of the firmware is only for 434 and 915Mhz. Anything else is falling back to 915Mhz init register set.
Interestingly the register tables above 19kbps are the same for 434Mhz and 915Mhz, so I assumed that 868Mhz sould work. And it seems to be a right assumption, I managed to get a solid link between two 868Mhz modules. I did not made a range test, but within a couple hundred meters it was fine.
    EOSBandi
Dear Andras,
I bought a couple of 868MHz module and I don´t know how to make them work
Could you please help me.
I put every module in a litle text board this board is attached to a normal FTDI Basic
I conected this way
FTDI         Module
VCC         3,3V regulator  VCC
GND         GND
TX            Rx
Rx           Tx
DTR         NONE
CTS         NONE
I have send some sentences from a Hyperterminal Program connecting  @ 9600bps with the Com port (USB) and @57600  and they work, I know because I put a bridge ai the air module Tx-Rx and I receive at the computer the same sentence I write.
BUTTT.
When I try to connect them to the 3DRadio Config program and there is no way of connecting them
Could you please tell me some advice.
Alberto
HM-TRP modules are work as a transparent comm module by default, BUT they are NOT 3DRadio modules. To use them as a 3DRadio module, you have to program the appropriate bootloader and the firmware. To do that you need a C2 programmer (to program SiLabs uProc).
    Andras
Thanks Andras.
I undertand I can make a very good modems with the bootloader and the firmware.
I have been using APC220 433 radio modems. but I would like to fly with 433 RC and I would like to use these modems. When I used the APC 220 I think they do not have very much programming  because the only parameters I changed were the baud Rate (to the comuter and drone and the wireless one.
I would like to try these modems with the APM 1.4 and a Mikrokopter (I was using the APC also)
I would like to program  just the baud rate as 57600 ground and wireless but when I try I thnik I did something wrong.
I type the sentence
AA FA C3 00 00 E1 00 to change the wireless baud rate (57600) and the module record this parameter
When I type the nest sentence,
AA FA C3 00 00 E1 00  to change the UART baud rate (57600) I could not talk to the module anymore.
I did a new connection with 57600 baud rate but it does not answer the correct thinks.
I am not very clever in programing and electronics, but I would like to do it.
Could you please tell me some tip to make then work.
Thanks a lot
Alberto
Hi Andras,
After seeing this posting I have added the 470MHz and 868MHz register tables to the SiK firmware. If you update to the latest 3DR radio firmware you will get full support for your 868MHz radio.
Cheers, Tridge
Hi Andrew,
Can this update be done with a bootloader and .hex image? I don't have the programmer and would like to change frequencies...
Cheers,
Minh
Hi Minh,
If you mean you have a 915MHz radio and want to run it at 868MHz, then for it to really work well you'd need new hardware. The 868 modules have a different analog stage than the 915 modules. If you run the 915 radios at 868 you will lose a lot of your signal (somewhere around 80% loss).
If you want to run a 915 radio at 868 anyway and don't mind the signal loss then you don't need a firmware change. Just configure it for 868MHz. I deliberately set the range of allowed frequencies for the 915 radios to include the 868 band, in case people wanted to do this despite the large loss.
Cheers, Tridge
Thanks Tridge,
I might as well give it a go and see how much of a problem it is. I'm guessing it will limit the air rate mostly?
Anyhow it doesn't save the config. I must have the wrong firmware version. Is there a binary file I can download from somewhere?
