Hi there, I was wondering if anyone here could point me in the right direction.
I need to find a high-quality, long-range, lightweight transmitter/receiver to patch into a Canon 5D or Red Epic for a UAV (Cinestar 8).
I already have a transmitter/receiver for the FPV camera, but essentially what I require is the ability to stream HD or SD to a monitor on the ground.
Any help would be much appreciated.
Check out the Teradek Bolt or Paralinx Arrow. The range will be similar to Wi-Fi devices but there's no discernable delay and there's no video compression. If you want longer range you'll have to make some compromises like SD, compression, FCC licensing (if in the United States), or much higher cost to maintain HD at a longer range.
