Hi every one.
I've faced with a problem.
I use 3dr solo and MP for survey missions.
But when I tried to process images for orthomosaics after mission and did geo references to images I received coordinates in a wrong format without the dot.
I need coordinates in wgs84 but what I've got in "location.txt" after processing as example:
#name latitude/Y longitude/X height/Z yaw pitch roll SAlt
DSC00285_VIS.JPG 472042753 388907721 164,300003051758 319,62 -0,27 5,44 0
latitude and longitude are without the dot for this coordinate system.
What should I do to fix it?
Thank you!
  • I've used metric coordinate...
    And what I've noticed:
    When I try to do geo referenced photos by CAM message Synchro I received wrong syntex without dot after two first symbols:
    What I have when to do geo reference by Cam message synchro:
    3702315441?profile=original
    But when I did it by time offset all were okay.
    And I received true coordinate:
    DSC00285_VIS.JPG 47,2042753 38,8907721 164,300003051758 319,62 -0,27 5,44 0
    Does anyone know why it happens?
    How is it fixed?
    And how can I replace commas by dots in log from mission planner before then photos get geo areference?
    Thank you for your answers!
