Xbee signal interference or noise.
hi all!
I have two Xbee pro 900 XSC modules, two 900 Mhz Duck antennas, a Xbee explorer USB and a Xbee explorer regulated.
I have setting up the APM at 57600 and the Xbee modules at 57600 too.
On happy killmore GCS I can connect but see so much interference...
and I can not connect the Mission planner GCS....
I used the X-ctu digi software for config the Xbee´s following the DIYDrones manuals...
Is there any way to clean the interference signal? Why is this happend?
Please need help
  • ok I understand.. so, I read on some forum that exist the possibility of increase the mavdelay from 15 to 30 in mavlink_gcs,
    but I dont know how to do that...
  • You CANNOT, I repeat CANNOT set the 900 XSC baud rate above 9600. Anything higher than that will cause checksum errors like crazy.
    Back off baud ratse to 38.4k and see what happens..
