Yet another alternative for ...
Few days ago I've mentioned in other thread about new project of alternative transmission.
Now - more details.
Phase 1:
Universal RC/data transmission module - 434/868 MHz, 500 mW (27dBm) regulated power.
Interfaces::
- RF-SMA for antenna,
- PPM in and out
- 9 channels - servo type as in standard RC Rx,
- serial interface - hardware and software compatible with 3DRadio,
- miniUSB - parallel to serial.
Software, after power-on, is "listening" on PPM-in port - if there is correctPPM signal - then "ground module" procedures are activated, if no - "air module".
Configuration - via Mission Planned / 3DRadio config software / dedicated PC/Mac/IOS/Android applications.
RF power regulation - 3-position switch (micro=range check/binding, std=100mW, hi=500mW
RF Module - Dorji DRF4432F27
CPU - STM32F103CBT6.
Phase 2:
500 mW, 5.8 GHz video tx with additional functions:
- 3 switchable video inputs: 2 - composite video and 1 HDMI. Switching by standard RC servo-type interface,
- photo camera trigger - IR/relay/OC transistor
RF Module - Airwave
CPU - STM32F103CBT6
Phase 3: Integration.
Products from phases 1 and 2 with some more on single boards:
"Ground" - functions from module phase 1 and: interface for potentiometers and switches/buttons for build stand alone (without RC tx) solution; drivers for antenna tracker - 2 servos/2stepper motors with "polulu protocol" for Mission Planner compatibility, GPS/IMU for antenna position (for moving ground stations), 5.8 GHz diversity receiver, MinimOSD compatible OSD with outputs: "pure video" / video+OSD / OSD only.
"Air" - functions from modules phase 1 and 1 and: output for servo for pan tracking for video tx antenna, GPS module for GPS+Glonass satelites, power measurement (current/voltage) used by video and data transmission, GSM/GPRS for SMS message with lat/lon sending in case of system failure, lost control, etc.
Time:
Phase 1 - PCB design almost finished, All parts on the table, Monday will sent it to production - 2 weeks and 5 sets for beta tests will be ready <- betatesters welcome...
Phase 2 - next month - now waiting for HDMI-to-composite IC's for finishing design.
Phase 3 - few units for beta tests - January 214.
All comments, ideas - welcome.
to be continued/updated...
  • This sounds too good to be true :P In fact it sounds very much like what we would call a "egg laying wool milk sow" XD
    Well I hope that you aren't going megalomaniac.. but I sure hope that you succeed building it! It would be the perfect solution for the problem I'm facing now.. even though I'd prefer 2.4Ghz VTX :D
    Keep us updated!
  • Hi Marek,
    what is the status of this project?
    I think there are still many people waiting for something just like that!
  • Is any price estimate yet?
    Too much features for me to betatest easily ;-)
  • Schematic drawing for module phase-1 almost ready...
    Comments welcome!
    Hardware possibilities:
    - transparent serial channel. P15-serial and P16-USB as interfaces.
    - up to 12 PWM servo-type channels (50/100/200/400 Hz - software selection)
    - servo channel 12 - configurable: servo or RSSI output (software+CB2)
    - transparent PWM channel - P13 - PPMin/out
    - RF power - via 3 position switch connected to P18 or via servo channel - configurable by software setup
    - DC power - can be delivered from servo rail or separate servo and electronics (via serial interface) (CB1)
    - JTAG interface (P19)  and boot selectors (P17) - only for prototyping/test modules.
    - binding - via bind button (S2) and/or software (possible one-to-many, one-to-one, many-to-many RX/TX)
    - PPM output can work concurent with servo channels.
    Faza-1.pdf
