  • @ Josh, They line up and plug in.
    @ Chris, yes both are plugged in.
  • Joseph, will you check both ends of the mag cable? Make sure that the female terminals in rhe connector are lined up with the openings in the plastic housing of the connectora, and also check the male pins on the APM I2c port and the mag port of the GPS.
    Just to be clear, you are connecting TWO cables, not just one, right?
  • Yes. I am getting GPS lock. But no compass movement and when I test it in terminal window it say compass failed to initialized. This was on both units. On 3.x firmware.
    And you're sure you've plugged the mag cable into the right ports on both GPS and APM?
  • Yes. Is there a setting to tell it that the mag. Is external? I tried both GPS/mags I got today and neither will initialize.
    Are you using ArduCopter 3.x code?
  • My apm 2.6 is not initializing the mag. What am I doing wrong?
  • Kevin,
    The instructions for disabling the APM 2.5 onboard magnetometer are here: http://copter.ardupilot.com/wiki/common-external-magnetometer-for-i...
    That's all you need to do in order to use an external magnetometer like the one built into our new GPS.
  • So can I use this new GPS system on my APM 2.5? If not is anyone interested in a $70 APM  2.5?
