Arducopter 2.0.38 Flight test - Wind effect
I want to add this discussion to record experiences in flight test from 2.0.38 and on mainly in RTL, LOITER and AUTO. Also to analise the effect of the WIND, that for me is THE big problem. I´ve tested several days my copter in different wind conditions. Below is a summary of my conclussions.
RTL flight tests
We can say that RTL works, but depending on wind conditions and direction of the wind in the moment of RTL.
Upwind. This is the best situation. The copter aproaches slowly the goal in a straight way more or less ( the goal is closed to the cross of roads in the images)
wind = 10 knots SSW
SUCCESFULL TESTS
3689418750?profile=original (log 26_file 1 attached)
The example below, ended well but it makes a path not logical to reach the goal (why?)3689418821?profile=original
(log 21 file 1)
Below is other succesfull RTL, but the path  took one complete turn to reach the goal probably due to the wind
3689418771?profile=original
(log 23 file 1)
NON SUCCESFULL TESTS
In all this test the copter diverged strongly and it was recovered THANKS to the SIMPLE mode, that is essential to survive to big crashes.
Below is a tipical divergence. It starts downwind and then enter in a divergent spiral. (Red curve shows the final SIMPLE mode to save the copter).
3689418786?profile=originalDownwind - other diverging RTL
3689418852?profile=original(log 28 file 1)
Other problem that happens to me is the delay in reacting once the SIMPLE mode is activated to save the situation. The yellow curve shows when SIMPLE is activated but it responded some seconds later.
3689418845?profile=original(log 22 file 2)
Upwind RTL. Another example of bad path to reach the goal
3689418625?profile=original(log 19 file 2)
Tomorrow I will add more LOITER and AUTO (exciting) experiences.
  • AUTO flight tests
    Well... this is really exciting.
    First to comment: the function TAKEOFF. When activated AUTO the copter lift up to the starts and beyond... I repeated several times (4-5) and only in one case (just after restarting and wayting for GPS) it did what was expected (lift up to 6m and wait some seconds) . So I decided to eliminate TAKEOFF and simply use a first WAYPOINT close to home at 6m heigth. It was not recorded in any log (I don´t know why)
    This is the goal path:
    3692249662?profile=original
    This is the first try. Started from HOME in the floor. Then when to WP#1 but  due to the wind effect, a semicircle path is done. Then overshoots at WP1 and started a diverging spiral. Then, I recovered the copter in SIMPLE mode as usual (purple path) (log 11-12 file 1)
    Wind is allways from SSW - about 10-12knt
    3692249626?profile=original
    Second try, exactly the same process.(log 14-15 file 1)
    3692249648?profile=original
    Wind increased a bit. Below shows two tries together (red and blue line) that diverged before reaching WP#1. Purple line is in SIMPLE mode to recover.
    3692249684?profile=original
    In conclussion:, something to do with the wind perturbation.
    This ends the first set of flight tests reports.
    Hope it will serve to improve the code, and animate others to report their experiences.
  • Jason:
    going upwind it works most of the time, but downwind overshoots also home location (helped by the wind) and then start to diverge (see figure of case log 28- file1) . I agree that a 2D rate controller is the solution.
    In general, if the copter goes out of the line of the wind direction (either in loiter or RTL or WP) then there is a big probability of entering in a diverging spiral (that acelerates more and more). Sometimes a simple gust, while in loiter or RTL,  initiate the diverging spiral.
    Angel
    Just got back from tests and I think I know the problem now. Basically the crosstrack correction is making the quad go too fast and overshooting the home location. That's why downwind and upwind work and crosswinds overshoot. I basically have a 1 dimensional rate controller and I'm going to have to change it to a 2D rate controller. In the mean-time, turn Crosstrack kP down to 0 and see if that helps overshoot.
    Jason
    I am doing tests today. I'm going to make some changes based on this and go fly them right now.
    Thanks!
    Jason
    Hi jason,
    i doing the same test , and i have same result of your . I saw that when there is a windy day with rtl the quad doing a semi cirlce when going to starting point.
    Best
    Roberto
  • My understanding of the nav update code in ArduCoptermega.pde is that the RTL mode switches to Loiter mode when close to the Home location
    case RTL:
                // are we Traversing or Loitering?
                wp_control = (wp_distance < 4 ) ? LOITER_MODE : WP_MODE;
    I assume that the '4' in the code is meters
    Looking at your examples it seems that the issue is in the Loiter mode as the quad copter nears the home location.
    Have a look at the 2.0.39 Code. It has a new set of PID values for Loiter
    It may help
    -Andrew
  • continue reporting...
    LOITER flight tests
    In general, it works. But sometimes it diverge due to the wind (probably) and PID settings.
    Below is a typical LOITER with light wind (8-10 knt). It remains  in about 4m radius circle.
    3692249104?profile=original
    (log 42 file 1)
    Other succesfull example, same wind conditions. Smaller radius (3-4 m)
    3692249043?profile=original
    (log 8 file 2)
    Below is an example of starting well, but after a while, diverging (similar than loiter divergency) due to wind gusts increase, probably
    3692249057?profile=original(log 13 file 2)
    Below is a loiter with more wind (12knt), still stable but more radius (10m)
    3692249126?profile=original(log 39 file 2)
    AUTO tests reports coming soon...
  • Not yet, For the moment I´m trying with defaults and learning how it works.
    Nicely documented! Have you tried turning up the Nav P or I terms?
