Here is documentation that I made for the ArduCopter Beta Frame as well as thoughts and a short flight test video. All of the pictures can be clicked on for full-resolution and the videos are in 1080p.
Assembly:
Open Bag #1 and take out 1 of the Main Frame boards. You'll also need 4 of the M3 x 25mm Male-Female Nylon Spacers and 4 of the M3 x 6mm Nylon screws that are in Bag #9. The main frame is supposed to
support both '+' and 'X' configurations. Take each of the spacers and put them over the hole closest to the
center of the three holes near the outside edge of the Main Frame board with the female side down. Secure each one with a screw from the bottom of the board. The spacers should NOT be installed over where the aluminum arms will be which depends on if you have a '+' or 'X' configuration. Now, take 4 - M3 x 20mm steel screws out of Bag #9 and place them through the innermost hole. These will end up going through your aluminum arms, so place them accordingly. In anticipation of installing the Power Distribution Board and to make it easier for ourselves when we do, it is best to install the spacers right now. Open Bag #3 and take out the 4 - M3 x 12mm Male-Female Nylon spacers and the 4 - M3 Nylon Nuts. Place the spacers through the innermost holes with the female side up that are not being used by the steel screws. These spacers should line up with the longer spacers already installed. Secure them from the bottom side of the board with a nut.
Now, remove the second Main Frame board and line it up with the first one. These two boards will sandwich the aluminum arms. Take out the 8 - M3 x 20mm Nylon Screws and 8 - M3 Nylon Nuts from Bag #9. Two of the nylon screws will be on either side of an aluminum arm and the steel screw will pass through the arm. Place the nylon screws through both Main Frame boards in the outermost holes of where your arms will be. Place a nut just barely on the other end; we will tighten it later.
Now, choose the size of aluminum arm you want to use. If you look at it, you should an elongated hole on both ends. Find the side where the hole is furthest from the end of the arm. This is the side that should face up and the end that your motor will mount to. The motor mount parts are located in Bag #7 and #8. The upper part of the motor mount is the larger piece. Take a M3 x 25mm Steel screw and place a steel washer followed by a nylon washer on it. Push it through the lower motor mount, the aluminum arm, and the upper motor mount. Take your 16/19 mm spacing motor and line it up with the holes on the end of the upper motor mount and the steel screw you just put it. Tighten the steel screw and use the mounting screws that came with your motor for the remaining three holes. Find 2 - M3 x 25mm plastic screws and nuts and place them through the remaining holes of the motor mount. These should press the motor mount pieces tightly to the aluminum arm and brace both sides of the arm. Do this for all four of the arms.
Slide each aluminum arm between the nylon screws of the Main Frame boards and pass the steel screw through them. Secure the steel screws on the bottom with the 4 - M3 x 10mm Female-Female Nylon Spacers found in Bag #4 and tighten the nylon screws so that the Main Frame boards are snug with the aluminum arms.
Take out the Battery Mounting Plate and the 4 - M3 x 6mm Nylon Screws from Bag #4 along with the velcro battery strap from Bag #9. Thread the velcro strap through the batter mounting plate ensuring that you have the correct side of the strap so that it will stick to itself. Make sure the recessed screw holes are also on that side.
Line the screw holes up with the nylon spacers on the bottom of the Main Frame board taking note of which direction you'll want the battery to be. In my 'X' configuration, I want the length of the battery to be facing straight forward and aft. Secure it with the 4 nylon screws.
Now, look at the Power Distribution PCB found in Bag #3. I didn't bother with using the PCB to route the signal cables of the ESCs because my cables are long enough to reach the APM directly. Notice there are 3 distinct trace areas on the PCB. The largest one in the middle is the positive and the two others are negative. Since the negative areas are not connected, we will bridge them together in two places with the 18 AWG cable included in Bag #3. Pass those through the bottom side of the PCB. The positive and negative cables from each ESC and from the battery need to be soldered on. Also place an additional solder layer of about 0.8 mm thickness on the traces. In my case, since this is a prototype, I want to be able to easily swap out parts like motors and ESCs. So, instead of soldering my ESCs directly to the PCB, I have EC3 connectors soldered on and I am not mounting the cabling inside of the arms.
Place the PCB into the 12mm nylon spacers and secure it with 4 - M3 x 6mm Nylon Screws from Bag #3.
Now, take out a carrier board from Bag #1. I used some nylon screws from the extra parts bag to mount my ArduPilot Mega board. Normally, you should mount the board so that the edges are parallel with the side of the carrier board, but mine is mounted at a 45 degree angle. I'll explain later in my thoughts section. Keep in mind when attaching your board that the edge opposite the right-angle headers must be the front of the Arducopter.
Place the IMU shield on top of the APM.
Take the second carrier board and attach the magnetometer (if you have one) as well as the receiver from your transmitter. If you take a look at the magnetometer, there are two arrows labeled 'x' and 'y'. The coordinate frame for aircraft designates the x-axis out the nose and the y-axis out the right wing. So, in the Arducopter, the x-axis should be pointing to the front and the y-axis to the right.
A velcro sticker is supplied in Bag #9 for mounting the receiver, but you may not be able to use it. I later found out the velcro adds too much thickness to the point where the protective dome doesn't fit, so I have mine secured instead with zip ties.
Place the carrier board that has the APM and IMU on top of the 25 mm Nylon spacers already on your frame. Take the other 4 - M3 x 25mm Male-Female Nylon spacers out of Bag #9 and screw them on top of those. Place the second carrier board with your magnetometer and receiver on top of those spacers and secure with a M3 nylon nut.
All of the parts for the protective dome and landing gear are in bags #5 and #6. The upper and lower dome center have elongated slots in them that the protective dome arches slide into. Secure with 2 - M3 x 20mm
Plastic screws and two M3 plastic nuts. The top carrier plate will have more room if you hold the dome centers with the nuts being placed on top and the screw head on the bottom. Two extra nuts are included for both sides of the dome center, but I don't think they are necessary as the dome arches are supporting it.
If you look at the end of the arches, notice that there is material removed from one side of it between the 3 screw holes. This is the side that is against the aluminum arm.
The Landing Gear Fins also have material removed on one side and they attach with 3 - M3 x 20mm Plastic Screws and Nuts. Keep the nuts loose until all of the landing fins are on so that you can center the entire Protective Dome on the Arducopter. Once it is centered, tighten the nuts. (Some people may find it
easier to attach the Protective Dome Arches and Landing Fins to the aluminum arms and then snap the Dome Centers in place)
The GPS is placed in the top dome and is secured with a zip tie.
Thoughts:
When I initially received the box containing the ArduCopter Beta Frame via EMS Express from Jani, I was surprised how small it was. Upon opening it, everything was neatly packed. There was an 8 1/2" by 11" piece of paper with a parts list and letter on it along with individual bags containing parts and two sets of aluminum arms (21.5 cm or 28 cm) wrapped in padded foam. I set about putting it together even though there were no instructions available. It definitely helped that the bags were grouped together into ones such as 'Battery Mount'. That way, I at least knew which sizes of screws and spacers belonged to each component. Like my Power Distribution PCB video, I filmed myself putting it together; although it wasn't always correct or in the optimal order as I would discover later. I might post that video later.
I'm using 12 x 3.8 APC props and decided to go with the longer of the two sets of included arms at 28 cm. All of the holes were drilled precisely and I didn't have any problems with alignment. However, I had a fair number of quality problems with the plastic nuts. I don't know if it was because the threads were crooked or what, but quite a few of the nuts wouldn't go onto the screws farther than the initial bit. Flipping around the nut didn't help. Thankfully, Jani included a 'Beta Spares' packet that provided enough spares to cover the ones that didn't work.
One of the problems I had was with Bag #8. As you can see in the diagram below, the parts list didn't match the parts I received and the parts received weren't all the parts I needed to mount the motors. The innermost screw on each motor is a steel screw that goes through both motor mounts, the aluminum arm, and into the motor. Only one of these screws was included for the entire frame. None were included in the Beta Spares bag, so I went and bought some at a local hardware store. The motor mounts themselves are a fantastic design. I love not having to use the 'plus' motor mounts and the spot for an LED to slide into is a nice touch. I thought there was supposed to be a cover for the LEDs that keep them pressed in their slot. If there is, some longer plastic screws will be needed to pass through the extra thickness.
Another problem I had was with '+' versus 'X' configuration. It is supposed to allow for both, but I don't see how to mount the carrier boards for the 'X' configuration and maintain the same structural support and ease of mounting the APM+IMU. Ideally, an edge of the carrier boards faces the direction of flight so that there are no spacers in the way of mounting the APM+IMU and so there is nothing blocking the I/O ports of the APM. With the '+' configuration, it works, but with the 'X', you're either faced with mounting the point of the carrier board
facing the direction of flight like I've done on mine, or mount it the other way. The problem with the other way is that the Aluminum arms are there. I could increase the distance between the main carrier boards to allow a screw head to fit between the top carrier board and the aluminum arm, but then it doesn't benefit structurally
from having the main frame board being pressed against both sides of the aluminum arm. Another option would be to drill an extra hole all the way through the aluminum arm. With the corner facing my direction of flight, I have everything mounted, but it is not perfect and some of the I/O ports are blocked. Another thing is accessing the APM+IMU. It is difficult to access things like SW1 for data logging.
A velcro sticker was included for mounting the receiver (I have the one that comes with the Turnigy 9x) to the top carrier board, but the velcro added too much thickness so that the receiver couldn't fit underneath the dome center. I just used cable ties because they didn't add as much thickness although they are still pressing
against the dome center. The dome arches were a little hard to snap into the dome
centers. Maybe increasing the notch that faces upwards would provide a better lock. There really isn't a reason the top one has to be flush with the upper dome center. The bottom one is nice being flush so that it doesn't restrict mounting on the top carrier board. I would definitely like to see some longer landing fins and maybe an optional protective dome that protects all of the electronics instead of just protective arches. With my 4900 mAH battery, there is only about an inch of ground clearance for the battery. Combine that margin with a soft lawn and the small surface area of the landing fins, the fins slip into the ground and the battery may take a hit on the landing. So, I'd like to see options for longer landing fins and some to permit a camera to be mounted beneath the frame. I imaged the battery mount is perfect for about a 2200 mAH battery, but my 4900 mAH might be about the limit of what it can
mount.
Could traces be added on the bottom side of the Power Distribution PCB to connect the negative sides? That way, two of the wires wouldn't be needed to jumper them. My view of this frame is to be bundled together with the electronics, motors, etc, to make a complete kit and make it easy for people to know what to buy and put together. Every little bit of wire and soldering that can be avoided would make it easier for people. I didn't even solder the connectors for the signals of the ESCs because my cables are long enough to reach the APM. Is there a benefit to routing them to the PCB and then adding an extra cable to the APM? It just seems like more complications and wire to me. Also, could some holes be added for the (+) and (-) of the ESC to connect to instead of just mounting them flat across the top trace?
A foldable frame would make it easy for transportation. I think this was designed for it and I see how removing one of the nylon screws bracing an aluminum arm on the Main Frame would allow for the arm to pivot around the steel screw, but wouldn't the Protective Dome also have to be removed to make it fold? Maybe we can find a way that would make it a quick process, but still be structurally sound in flight.
I just mounted my ESCs on the outside of the arms since this is a prototype anyways. I have Turnigy Plush 30A and I would need an extension to be able to mount the ESC on the main frame and get the cables through the arms because the cables on the ESCs aren't long enough.
These thoughts were all intended as constructive criticism. I am impressed by the design, weight, and especially the motor mounts. Great job on the frame Jani! I'd like to continue working with you guys to improve ArduCopter!
My whole flying setup weighs 2.85 lb = 1.293 kg. This is with Turnigy 2217 motors, Turnigy Plush 30A ESCs, and a 4900 mAH LiPo Battery
  • where in the world can i find this pbc man im goin nuts here anyone heeeeeeeeeeeelppp!!!!!!!!
    Tony, yes on arm locking there should be metal screw, metal nut and after that those 10mm nylon spacers.
    If you look that battery mount video from our wiki you can see those nuts.
    Wiki page: https://code.google.com/p/arducopter/wiki/Quad_Frame_Assembly
    Those are most important screws and also due they are under P-PCB it is hard to re-tighten them due you don't easy access on pan head. That's why there are "double nuts" eg metal and then nylon spacer.
  • @ Sandro
    Thanks! I actually have a larger space to fly in than that too...it was a little more wet because of rain though ;)
    Why aren't we following convention and using the magnetometer with the x-axis forward and the y-axis to the right side? That's how I mounted mine, but apparently that is not how it is working in the code.
    @Jani
    Do you know why your APM was blown by connecting all of the ESCs? I've been flying mine with all of them connected for over a month. Did it happen the first time you connected them like that, or did it just do it suddenly one of the times? When you say "mount APM on side of the carrier board", do you mean rotating it 90 degrees towards the vertical (e.g so that Output 0 is at the top)? You would have to have a variable defined in the code then to change which sensors are used for yaw, pitch, and roll.
    Those motor cables look nice since they're so long and already have bullet connectors on them.
    Just to make sure I understand what you're saying; you want me to put a metal nut on the steel screw, then put the spacer on, then the battery plate, and then the nylon screws through the battery plate into the spacers?
    And now few more answers on your questions and wonderings :)
    Folding: You don't need to unmount dome if you want to fold frame, yes you need to remove those 4 screws on edge of frame to let arms to move and the trick with dome is that you unscrew DomeCenter 2 upper nuts away and that way you can easily remove center. That also leads to another issue, there are plans to have a bit different type on locking mechanism on DomeCenter. On first times when you snap it on, holes are tight and they should be because those little taps that locks upper/lower parts will get squeezed while DC is on it's place. Everytime when I fold my frame, I just take out center, put two peaces back together and slide it to one of the arms while carrying my quad.
    Power PCB: As said, there might be different type of power pcb in future and on beta frame it was only single side pcb, retail back should have 2 side with trough holes. There are two main reasons to connect ESCs to P-PCB:
    1) to separate UBECs from different ESCs, that way user can easily take UBEC output from one of the ESCs and bring that power to APM with 2 pin cable that was included on P-PCB set. Many people has blown their APM while hoocking up 2-4 ESCs directly to APM output pins (including me & jose)
    2) future I2C jumpering can be done on this P-PCB too due signal and +5 pins does not go anywhere, they just have holes and if you look more careful, 1 of the pins has extra holes, these extras can be used as I2C bus connection to APM
    Fins: I could make fins a bit longer for retail set too. There are also a plans to make totally different type landing gear set for people who want to have cameras on board along with big camera holders. This frame in only generic level frame and most of the users will start with that. For more advanced users there will be expansion sets. As everyone can see.. It's rather useless to include big expensive landing gear installation to quad when 80% of the users are happy with small one. People who need it can have it.
    X Orientation: Your hunch was correct on drilling 6mm hole on arms under and then you can easily rotate carrier boards 45°. Other way is to mount APM on side of the carrier board and that way you can expose all connectors easily, also you can mount your receiver next to the APM. I have them side by side on my quad. Along the holes, i've been thinking to make small "slide" hole for those 4 screw and that way we could still make frame to fold. I'm still working on this issue.
    MotorCables: just today I received from factory our new ArduCopter motors. There are two sizes of them, one smaller for 8 - 10" props (1000kv) and then one bigger for 12-14" props (880kv) and they all have 35cm long connecting cables coming from inside of the motor and bullet connectors mounted on end of cables.
    Along with ArduCopter ESCs which are 20Amp ESCs and we are planning to get that auto calibration working with these due we should now have support for it on our ESCs. There will be also 30Amp version available for BIG boys :)
    I use on my battery mount 2200, 2650 and 4400 mAh zippys.
    Tony I also noticed on one of your picture that you did leave our those metal nuts from center screws under battery mount hexa spacers. You should put them on to make sure that they won't open because of vibration. Then just mount hexa spacers on top of them. There are enough screw left to mount them.
    Tony, Thank you for great review it gives a lot good information to develop frame packet to be even better. About Bag #8, yes it looks like few bags were missing metal screws, there should have been 4 metal screws, 4 metal washers and 4 nylon washers on every 8# bag. But for some reason few bags only had 1 of each. My deepest appologies, I will kick our quality control people (will go and buy size 12 shoe).
    Due this was a beta frame there will be some changes on future releases and one change will be on power distro pcb. We might include it as ready made or change it's design.. Let's see.
    Great review, thank you again.. This is just what Chris called "Just Do It!" :)
    @Muthanna, no we do not change those hole positions due different motors have cable outputs on different areas so it's rather useless to change them also then we would loose alignment from those holes and make mount weaker. I have here same motors from same manufacturer and even those can have different output for wires.
  • I’m building my own BASSWOOD Quadcopter frame and yesterday I figured out that when I make holes for the Turnigy 2217 BLDC motor I should place it in cross (not plus) on the mounting arm otherwise BLDC cables will be out of the frame. I think this issue is already there in Arducopter frame. If you agree with me, the holes need to be rotated as shown below:
  • You guys better hurry up, I'm getting tired of wiping the drool off my keyboard every time there's a ArduCopter update.
    Very nice, Tony! Loved the pictures and the high quality videos. BTW. You have a niiiice place to test flights. :)
    I think is better if you mount the P-Distro with cooper side pointing down to achieve less exposition as well as using the signal wires and the ESC pinheads from the upper side. If you not cutted off the positive wire from your ESC's BEC, so you're sharing all the power lines on APM. We have no conclusive tests about it, but it isn't the recommended way. This is why we have those additional wires and the AMP/MODU slots for the signals and for get the power from only one of the ESC's BEC.
    *** The official way to mount the Mag will be upside-down and wires pointing to the IMU's mag connector side. Probably you saw the way we did on old 3D renders and old pictures. It was changed.
    Tony, thank you so much for your thoughts. It's a lot important that Beta testers give us their impressions about the frame and everything else. ;)
    Best regards!
  • Anyone know what the payload for the Arducopter is?
  • @ Bill
    Jani opened a preorder for a few people. He's waiting for feedback from those who received them, then will make some changes before entering full production
