Posted by Jose Julio on November 13, 2009 at 9:51am
I have implemented the dynamic weighting of accelerometer info and works very well...I have made some flight test and the IMU can register some difficult maneuvers like rolls and loopings...Well, rolls are not difficult for an IMU (there are no centrifugal forces involved) but loopings are quite difficult.I´d also start to make some test of the robustness of the IMU/stabilization in difficult flight conditions. I flight in manual mode, do some "strange" maneuvre and then let the stabilization to restore a "normal" flight condition.... First tests were satisfactory but I need more tests...Yesterday I made some videos showing the problem of vibrations/aliasing of the actual ArduIMU code:and another video with the solution implemented (I explain this on the first point of the previous post):Ah, this is the code of the dynamic weighting of accelerometer info:// Calculate the magnitude of the accelerometer vectorAccel_magnitude = sqrt(Accel_Vector[0]*Accel_Vector[0] + Accel_Vector[1]*Accel_Vector[1] + Accel_Vector[2]*Accel_Vector[2]);Accel_magnitude = Accel_magnitude / GRAVITY; // Scale to gravity.// Weight for accelerometer info (<0.5G = 0.0, 1G = 1.0 , >1.5G = 0.0)Accel_weight = constrain(1 - 2*abs(1 - Accel_magnitude),0,1);And on the drift correction we apply this factor:...*Kp_ROLLPITCH*Accel_weight;...*Ki_ROLLPITCH*Accel_weight;...JJ.
Yes Chris, I am talking with Jordi and Doug to integrate this modifications on ArduIMU code... :-)
Really my hardware is an old 5DOF IMU from SF (with IDG300) plus an LISY300 (for yaw) from ArduIMU hardware but the problem described here and the solution would be the same...
Video technique was a chance. First time I see the effect I think Oh this is a !!!!!!!! but then I take a look again and think that it´s good for this explanation becuase you can see the plane and propeller....
Doug, thanks for the reply. Can you work with me and Jordi to integrate the changes once you've nailed them? We really appreciate the work you guys are doing!
That is a great improvement - from not working to working. The yaw still has slight drift when powered. I wonder why the yaw moved slightly but not the other axis.
JJ.
Is this using the ArduIMU+ version 2 (flat) or version 1 hardware?
Matt, the yaw is not drift corrected on this video because we need that the GPS moves to get a heading readout to correct yaw drifts...
