  • Hi, I know I come 2 years later...
    But for who come here from a google search or another way, here is the solution :
    On the Turnigy 9x(r), go in your model settings, you will found at the bottom of the first setting page (1/11) the E.limits setting (extreme limits), enable it, then go to Limits page (6/11), increase the value of the channel 3 to have a PWM value below 780. Then make you failsafe settings on the receiver (push the bind button one time), replace your normal settings on the 9x(r) and you're done.
    Hope to help anyone goes here ;)
  • I just set up my fail safe using you method, I set the flightmode to RTL and than pushed the FailSafe button on the FrSky receiver. It does work but I'm very sure that when I first time and the only time I set the failsafe , a few months ago after moding my Turnigy 9x, I did it using a different method, which I can't really do it again.
    I had to set the throttle channel to send a PWM bellow 980 and I remember I accomplished this by changing something in the LIMITS menu of my 9x (firmware : Er9x) I tried now again and can't make the 9x send a lower PWM. Anyone around to point me in the right direction? maybe you know a link or a video that explains how to "teach" the receiver to send a lower value on throttle channel when it's in failsafe mode.
    I don't really understand how the failsafe is triggered now, using Mark Harrison method, anyone around that could explain in a few words, maybe if I understand what's happening I'm more confident in my failsafe setup.
    thank you.
  • Thanks Mark, but I couldn't find any info on the actual usage of telemetry with the 9X. Have you bought a separate telemetry screen to attach to the module or programmed the 9X to show the data?
    P.S. When I say 9X I mean er9X :-)
    @Jon, definitely worth it.  My collected notes are here:
    http://eastbay-rc.blogspot.com/p/eastbay-table-of-contents.html
    search down for FrSky
    EastBay Table of Contents
    All Posts on EastBay RC 2010-07 Videos - Electric Combat Planes I'd Like to Try: "Baby Bam Bam" $1.00 Flying Bat Plane Beginner Guides ...
  • Has anyone actually utilized the FrSky modules telemetry with the 9X. There are some hits on google about it but I would like to see it in action and also hear if it's worth the hassle.
    Thanks Dean!  You definitely want one of the JR compatibles
    http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=...
    The difference between these two is telemetry and no telemetry.  I've got the older, no-telemetry model.  Get the telemetry model... it's cheaper (!) and I think they're phasing out the non-telemetry units.
    Good Luck!
    Paul, thanks!!! :-)
  • I love your avatar, Mark!  You look like the happiest guy on the planet.  You're either surrounded by family, toys or both.  I'll have what you're having!
    Paul
