Here are some instructions and suggestions to assemble the ArduPilot Shield. But remember: You can always do it your way. You can buy a complete kit here.
First i recommend to solder the headers (either female of males) in the Ardupilot board, do not matters if you put the females header on the shield or in the ArduPilot board. I personally recommend to put the female headers on the active board, in this case ArduPilot. If you have male pins and you make contact with something you may cause a short circuit and toast it, otherwise with the female headers the board is "protected".
After soldering the headers on the Ardupilot board, place the opposite headers on top of it as indicated in the picture. In this way the pins will be right aligned and you will be able to remove it easily.
Then place the ArduPilot Shield on top and solder it. Be careful of not add too much soldering or the liquid solder may go to the button and you will be unable to remove the shield (happened to me once!)
Ready? Come on hurry! The result is a nice and well aligned shield. ;-)
Now you can solder the pins for the FTDI connector. Remember you can buy the official FTDI cable in our store, here. Has a long cable and is very practical on field when you are testing.
Now get some servo extensions like in the picture. You can buy them in our store too here
Now cut them slowly and painful, no mercy please! You will use both ends later.
Now solder the female side of the servo extension to the board. This connector will go to the receiver. I recommend to cut them as short is possible to void the big ball of wires inside the airplane. I personally like to remove the Power and Ground cables to the other connectors, leaving just the signal to eliminate the "big ball of wires", or at least leave two with Power and Ground to add some redundancy.
Now turn the Ardupilot and solder a jumper wire from "digital 8" to the "mux3", in order to enable the throttle control!
The color of the wire is your choice, white looks nice with SparkFun logo. ;-)
Did you remember the redundancy thing? Well i extremely recommend to add hot glue or something to holds the wire in the bottom of the board. The everyday use will fatigue the wire and eventually will broke. I have learned this the hard way. One day the receiver rudder cable failed and i was unable to manually control it (i was flying!!!!), i was expecting to finally lost my EasyStar forever and definitely jump to Funjet and never came back, but the Autopilot was working fine, because the failure was from the receiver to the multiplexor. Anyway, i just switch to RTL mode and EasyStar was flying around me and luckily at that time i was controlling the throttle manually so i cut the throttle and ArduPilot land the EasyStar nicely. Chris once mentioned: that the human variable is the problem.
Now is time to solder the Infrared sensors. This is up to you and you can use anyway you want. In my case i developed a custom and redundant cable (locked!).
A little bit of help with the FMA sensors:
The "Only For Girls" pin is not used.
You have a picture of the complete cable here with the FMA connectors. ;-)
Now take the other end of the servo extension and cut one cm of the power line (red wire).
Solder it in digital pin 6, this will be used as the "Remove Before Flight Plug" used to set home position. You can use any bind plug like this one or make you own (Also available soon).
And you can also add any external reset button as indicated in the green arrow. Also available soon in our store.
Now an extra precaution: Please zoom the picture and look the silver hairs at end of the connector. This is a potential threat! You must cut that little metal hairs, if not you may burn your boards! I also learned it the hard way. ;-)
You can add now the Power Divider Cable, in order to know the voltage of your battery, this cable must be connected in the positive pole of your LIPO.
And finally you can use a servo connector to plug your radio modem. That's what i did! This way is to noisy, modems require a lot of current, it will work but can cause some problems. I suggest to feed the radio modem with a direct 5V lines not coming from the GPS ports.
Here you can get 5V for the radio modem:
Schematic:
[UPDATE]: The IR port labels are wrong, they suppose to be A0,A1,A2,5V,GND.
[UPDATE2]: Assembly pictures of ArduShield V2 can are here.
Good Luck!
Comment by Torin Segstro on May 21, 2009 at 11:09pm
So, just to confirm, I can connect the power divider cable to my 3s lipo? (12 volts)
Comment by Matt on May 21, 2009 at 11:12pm
FANTASTIC build instructions Jordi!!!! Thank you
Comment by Jordi Muñoz on May 21, 2009 at 11:27pm
Torin, Yes to the positive pole!
Comment by Torin Segstro on May 21, 2009 at 11:31pm
Thanks Jordi, great instructions as always.
Comment by Matt on May 21, 2009 at 11:43pm
I think most people will have the male pins sticking up from their existing boards. It is really hard to desolder the male header pins from a board and re-solder. I learned that the hard way and had to throw a board out.
I also have lots of questions :)
1) For existing board users who had the jumper wire under the board from the VCC pin next to the FTDI over to the Bat+, do we need to remove that? It looks like your boards no longer use the batt +- on the arduPilot board if used with a shield.
2) What are analogue 3,4,5 used for now? I have only used analogue 0,1, 2 for the X, Y, Z
3) Previously we used digital 6, 7 only for jumping to switch the GPS into binary. What are the others in that row used for?
4) For inputs you have an extra signal next to the ctrl, ail (1) and elev (2), I assume that is for throttle. should we solder a 4th signal in for future functionality?
5) Will you be supplying some instructions for use of the new battery wire and modem plug?
6) For the IR Connector, I assume we can use the existing headers until you get the sensor plug in. Could you please let us know what that part is so I can buy locally here in australia? I would also like to discard the original FMA cables as they are inflexible and break easily. Is this part of the same IR cable you will sell.
7) and finally, for outputs we need some pins soldered in for the throttle servo (or esc) [output 3] that is not shown above. What will the 4th output be used for?
Sorry if they are noob questions, I just don't want to wreck my only board. Hopefully they will cover most of the questions that others want to ask too.
Matt
Comment by Edson Nobrega on May 22, 2009 at 2:33am
Nice build instructions! Thank you.
Comment by Mike W on May 22, 2009 at 4:41am
Jordi,
Why did you decide to go with the Dual Port version of the MPXV5004DP?
Is one port connected via a tube to the incoming air stream and the other left to receive non-pressurized air?
Would a single port version of the pressure sensor work for airspeed as well, or would that only be good for sensing altitude?
-Mike
Comment by Jordi Muñoz on May 22, 2009 at 9:09am
Mike:
That's a lot theory i have to explain, but yes one side is the static tube and the other is the dynamic one. Try to read this document from NASA:
http://www.grc.nasa.gov/WWW/K-12/airplane/pitot.html
Comment by Jordi Muñoz on May 22, 2009 at 9:24am
Matt:
Most of your questions have been answered before. But let go again:
1-If the jumpers are obstructing the shield, well.. You have to remove it (i guess). Maybe you can bend it in a right angle.
2-This question is answered here
3-D6 must be grounded in order to set home position. D7 is the one that enable and disable the GPS power. The other ones are used for LEDs and control the throttle servo(D8), only D9 is unused.
4-Yes the input four is for throttle. I don't think we going to use it later. At least us.
5-The battery wire do not need instructions, just solder it to the Positive + pole of you battery, the way is best for you. The modem is also option and there's many ways you can wire up your modem, i like the servo connector because is easy, and i only need TX,5V and GND.
6-Yes i will make a post when they become available. ;-)
7-You don't need to do anything else for throttle output, is already connected. And the channel four is not used (is the same as input five).
Comment by Chris Anderson on May 22, 2009 at 10:03am
Note for those unsoldering connectors from their existing board to fit the shield. The best way to remove connectors is to use a wire cutter to break each pin from their surrounding pins, then solder them individually and pull them out with pliers. Then use solder braid to suck the remaining solder out of the hole.
Comment
Season Two of the Trust Time Trial (T3) Contest has now begun. The third round was a reliablilty/aerial photography round for both planes and copters, which is now closed. Stay tuned for the next round, beginning soon.
© 2012   Created by Chris Anderson.
