Once in a while a need a new copter, this time it had to be a very small Y6 copter. It is meant for FPV flying, and that really works very good! It fits through really small holes, and it flies very precisely. It is my first Y6, and I am pretty much convinced by this concept. Ok, well, flight time is an issue.. I get 6:30 min with 1000mAh, but that is still reasonable for such an aerodynamic disaster.
Some more pictures can be found here:
http://shrediquette.blogspot.com/p/shrediquette-bolt.html
Some data:
Max. dimension 21cm
Roxxy 1815/25
Airace propellers
"CCD-Killer" CMOS FPV camera
mGUIDE controller
Turnigy Plush 6A ESCs + I²C->PWM micro converters
3S 1000 mAh battery
274g icl. battery & FPV equipment
The Knife! Love it. Great build too ;)
You have just the project i wanted to start next.
Can i possibly get a copy of the cnc cad files for the frame.
I can do everything else, but cad drawing is not for me. I will get it cut out of aircraft ply if you would be kinf enough to provide (for my personal use oonly of course)
I really qould be grateful (grovel)
Thnx in advance
Paul
some info i found the old end the new
http://forum.mikrokopter.de/topic-22399.html
@michel - It looks like the props are "Air Ace Propeller Set (L&R)" Part No. 5504955
http://www.wheelspinmodels.co.uk/i/89132/
http://shop.avicraft.co.uk/air-ace-propeller-set-lr-p-8158.html
from an Air Ace III EPO Mosquito III:
well i think that would also work fine. Every combination will have its advantages.
