Michael Fallon, the Defence Secretary, will today announce an innovation unit which will encourage individuals and companies to pitch ideas to a panel of experts. The best ideas will be fast-tracked with the support of an £800million fund over the next decade.
Projects which will be funded include a "micro-drone" with tiny flapping wings inspired by the biology of a dragon fly, which could have a "huge impact" on operations in urban environments.
It weighs less than two pound coins, is less than five inches long and will be able to fly at speeds of up to 45mph. The drone, which has been developed by a company called Animal Dynamics in Oxford, will be equipped with a camera and a microphone enabling it to carry out covert surveillance.
The unit will also fund new "Quantum Gravimeter" which is being developed with the University of Birmingham to survey underground structures.
Michael Fallon, the Defence Secretary, said: "This new approach will help to keep Britain safe while supporting our economy, with our brightest brains keeping us ahead of our adversaries.
“Backed by a defence budget that will rise every year until the end of the decade, it will ensure that the UK maintains its military advantage in an increasingly dangerous world.”
The Gravity Sensing team from the University of Birmingham has made successful outdoor measurements with their quantum gravimeter for the first time. The quantum gravimeter, designed and built in the labs at Birmingham, represents a significant step forward in developing robust quantum technologies for use in real-world environments. The technique of gravity mapping is already used by civil engineers for carrying out surveys – such as on brownfield sites – and detecting underground features. The Gravity Imager is intended to provide higher sensitivity and reliability for such applications, while also drastically reducing measurement time through enhancing the robustness to external noise sources. These first outdoor measurements of gravity represent a step along the way to starting full field trials.
The iSense project aims to bring the latest developments in ultracold atom science to practical applications by developing the technology that will turn laboratory-based instrumentation into portable and robust instruments and sensors. One most attractive application of such instruments would be to create a very compact, highly sensitive gravimeter, which is one long term goal of the Project.
The vision behind this project is to unleash the power of high-precision quantum sensors in a wide range of science and technology applications. In terms of fundamental science a precise force sensor based on the proposed technology would be designed and fabricated enabling a crucial step forward in detailed investigations of the Casimir force, or a search for deviations from Newtonian gravity. It would also be a tool for space missions, where compact, low power, ultra-high precision investigation of the local space-time manifold is required, or indeed where a distributed network of such sensors would be appropriate. The absence of local gravitational “noise” has the potential to achieve significantly higher sensitivity. All these scientific applications would provide extremely sensitive fundamental tests of our current theoretical framework in physics where small deviations from theory would be revolutionary.
Gravity sensors are already used in geodesy (e.g. ocean circulation, water balances, Antarctic ice levels, magma flows, etc), in the exploration of resources (location of scarce minerals, oil fields, etc) and archaeology (non-destructive mapping of sites and location of intact caverns). The improvements in precision and robustness offered by the quantum force sensor targeted in this proposal would not only make these applications more routine but offer completely new possibilities, e.g. the location and extraction of fragmented oil bubbles in current oil fields (potentially increasing the fraction of oil captured from today’s typical 40%). Other applications include the temporal supervision of carbon storage sites and monitoring of ground water, snow and soil moisture to improve climate models and our understanding of the global ecosystem.
In the longer term we anticipate novel communications paradigms (e.g. ultra wide band network timing) using a quantum-based position-time grid that would not require GPS, and exceed its accuracy by orders of magnitude. Further applications would become apparent as the technology develops, e.g. atom-based quantum information technology including computing and secure communications for a range of purposes including global trade exchange.
The technological breakthrough of transferring and adapting ICT into laser systems for cold atom preparation and control is the key essential and challenging step towards achieving these long term visions, as all rely on precise control of coherent, laser-generated photon fields and precision pulses. Laser systems based on integrated optics would not only be significantly more compact than standard laser technology but would also offer superior stability, adaptability and control, which will be crucial for precision measurements as well as quantum gate operations.
Gravimeter on a chip
The University of Glasgow have built a gravimeter on a chip that could offer a simple, compact and low-cost way of measuring gravity. The chip uses a microelectromechanical system (MEMS) that is similar to that used in accelerometers, which are ubiquitous in smartphones. However, the new device is about 1000 times more sensitive to accelerations than the devices found in consumer electronics.
The device has a sensitivity that is about ten times worse than the best commercial devices. According to the team, the device is still sensitive enough to detect a tunnel of cross-sectional area 2 m2 at a depth of 2 meters, and could be used to find an oil reservoir with a volume of 50 cubic meters at a depth of 150 meters.
The team is now working with a geological-survey company to develop a portable gravimeter that can be tested in the field. While the current design only measures acceleration in one direction, the physicists plan to create a device that works in 3D.
The team says that it could be produced for a 1000th of the normal $100,000 cost (so $100).
taken from: HERE
At least these guys have more money than that kickstarter dragonfly...
I'll take Rob's impossible battery and raise one gust of wind. Heck, even a mild breeze should be enough to make this a tiny spot on the horizon, never to be seen again..
I know, but the insect drone, is completely impossible until *radical* advances in battery technology occurs. And, that's not likely to occur anytime soon.
Nor is there any good reason to think that ornithopters are better than helicopters anyway. (single or multirotors).
But the worst part, is that these things are funded while it seems that the technology isn't even theorized beyond the point of having a 2D, external-only sketch that says "Look it has wings".
All true but in fairness the insect drone is for military use not invasive surveillence. GCHQ has invasive surveillence all covered.
@ Rob, +1,
England already has more video cameras per square inch than any other country, interesting they think even more invasive surveillance is a top priority.
Maybe in we can develop a market for a big, long handled flyswatter.
Or possibly the spring propelled bumbernet that could be an add on to your regular bumbershoot.
Should work well in London, where these are no doubt intended to be primarily deployed.
This whole thing is just... Facepalm
And of course there is also the Darpa funded Airovironment Hummingbird as well which has an endurance of 11 minutes now.
A helicopter is a proven large scale technology simply reduced to micro size - works fine.
The Hummingbird is actually about life size and weight, so it's aerodynamics are simply a copy of an existing organism.
The Robobee is alos weight for weight a copy of how a bee functions but is too small for a usable power source.
The Dragonfly hybrid shown here doesn't actually have a currently existing parallel at the same weight and size, although fossil records do indicate really big dragonflys at one time, so who knows maybe they can get it to work.
Still the current presentation seems really light, hopefully there is more to it than that.
The case for the quantum gravitometer seems much more developed although it looks like you'll still have to carry along some liquid helium to keep those atoms cold.
The British Army already has something that size that can fly for 20 minutes and has multiple cameras. It is a single rotor copter, of course. https://en.wikipedia.org/wiki/Black_Hornet_Nano
Interesting projects.
Insect mimic drones are all the rage in Universities now Harvard has been working on the similar robobee for at least 3 years now.
They actually have it performing quite well now (on an extension cord)
The real problem with these tiny things seems to be the power supply and right now, even the most exotic batteries aren't up to the task.
It will be interesting to see if they can beat that.
So far "the drone that has been developed by Animal Dynamics" seems like a 2D CAD sketch with no actual illumination of how any of it is going to work, wish I could get a couple hundred million pounds for that I'm pretty good at 2D CAD.
