This video shows the result of modifying a T41 Thinkpad to give a full colour sunlight readable display:
Full credit for both the idea and the modification should go to Nic Schraudolph from the Canberra MakeHackVoid group. I just supplied the old thinkpad to modify when Nic suggested that this would be a good way to get a sunlight readable GCS for the CanberraUAV project. Thanks Nic!
There are some more photos of Nic modifying the laptop here:
http://photos.tridgell.net/v/CanberraUAV/GCS/
Would some thing like this Samsung USB powered monitor be something "hackable" to make them viewable in bright sunlight so we don't have to wreck our laptops?
http://www.samsung.com/uk/business/b2b/products/displays/desktops/s...
Nic removed the cover, then just drilled holes and cut using a metal saw after measuring the right position. I didn't actually watch him do it, as I was distracted by another project during that part of the procedure, but I don't think there was anything magic involved.
Good luck with your 2nd try!
You could just grow your own shade.
I'm sorry to hear it didn't work out for your Tecra!
I think leaving the case in place and cutting a hole is definitely the better way to go. It gives it some strength and protection while travelling. We also left the clear plastic on the back of the LCD in place. It is probably better to just drag the menu bar to whichever side of the screen is clearest rather than trying to make the bottom edge perfect. For me the right hand edge was the best choice for the menus.
Are you going to have a go with another Tecra?
It should work with a wide variety of laptops. The main issue will be whether there is a lot of vital electronics behind the LCD which may be damaged by removing the back, or which will obscure the display.
The ideal laptop for this hack would have the ribbon cable connecting to the LCD at the bottom instead of the top. The T41 which we modified connects the ribbon cable to the top, which means you end up with the shadow of the cable on the display. We have thought about rotating the panel 180 degrees and shortening the cable, then using xrandr to flip the display back up the right way in software. That would get rid of the shadow.
Even better would be to find a model of laptop which is:
- old enough to be cheap on ebay
- new enough to be useful
- which has a bottom connecting LCD
- and which has very little electronics behind the panel
We chose the T41 only because I happened to have one which had a dead backlight (tt was my mums old laptop).
If someone does find a laptop which is a better choice then do please let me know. We're thinking of modifying several laptops for the CanberraUAV team in this way, and it would be great to find one which gives a really ideal result.
Also note that if you make this change, then to use the laptop inside you need to put a lamp behind it. I just use a little desk lamp. Alternatively you could rig up a LED backlight for inside use, and even have a little blind that you pull to convert it between inside and outside use. It just depends how much time you want to put into the hack.
ok, thanks Brian, I'll make sure I get that right for future posts
Nice post Andrew. FYI, I made a slight adjustment to the post prior to publishing. When the Image or Video is first item in the post it can automatically go to the front page for us all to enjoy. I moved the description line to below the video now it's on the front page.
Great Mod!
