I completed the airframe of my Modular Test Platform this week. It's core function is to allow me to test, repair, and replace each section individually, cutting down on prototyping cost and time.
The airplane itself is made from Bluecor aka Fan Fold Foam, and is supported by poplar wooden dowels. These serve two purposes: support the airframe by adding rigidity, and allow for each section to be removed and added as needed.
The wing is a Kfm2 airfoil, which has pretty good performance while being very easy to build. I added a little dihedral on the ends of the wing in the hope of gaining additional stability as this airplane, for the moment, does not have ailerons (which I can easily add later as this is modular!).
I'm still waiting on my Hobby King order to come in to replace a faulty motor/esc they sent me last time (I actually don't know what the EXACT issue is, it might even be my rx/tx) but when they come in I hope to complete the build and get it in the air.
In the end, this is all supporting my five year plan to fly an rc airplane across the United States. See http://www.mygeekshow.com/five-year-plan for the full details.
Great work Trent both on your designs and also for your videos, I subscribed :)
If I may suggest an idea, although I am a complete noob on this subject :P
You can make a wooden plate (P) where the motor could be attached with 4 bolts. The plate can be glued to the front 'bulkhead' (B) of the fuselage. In that way you can bypass the heat problem and use a lot of glue to attach the plate to the bulkhead. Also you can change the motor by simply unscrew the bolts.
PS. I haven't tried it, it is just an idea!
great air frame brother ... i take some ideas from your design.
tomorrow i transform my stick frame in the modular one.
