After our win at the 2014 UAV Outback Challenge and the many subsequent team discussions, CanberraUAV has developed a detailed set of goals for the next couple of years (see below).
The general theme is that we want to build up a capability to run real-life Search and Rescue scenarios in concert with the emergency services. We also want to collaborate with other like-minded organisations to do the same.
And as always, we remain committed to publishing our documentation and source code and remaining an “open” organisation dedicated to advancing the field of civilian UAV technology.
We always welcome new members. So if you see something on the list of goals that you’re interested in contributing to, let us know.
Finally, it’s been an amazing 4 years since the beginning of CanberraUAV and we can’t wait for what the next 4 years will being!
The following goals we aim to complete in the 2015-2016 timeframe.
Imaging
Lead: Tridge
  • Researching new cameras that are able to detect a shoe sized object at 100m altitude
  • Imaging software improvement to detect the aforementioned shoe
  • Record a reference set of images of an area with items strewn in it, to be used for development of imaging software
  • Support use of common cameras (ie Gopro), and document shortfalls
  • Provide comparison images between cameras (multi-camera flights)
  • Start using thermal cameras (if not too expensive) in the future
Airframe development
Lead: Jack, James, Greg, Darrell
  • Development of a rugged airframe (Bushmaster mk II) that can carry an imaging payload for a 1 hour flight and does not require a prepared runway for takeoff and landing
  • Investigate use of petrol helicopters and high efficiency multicopters as option
  • Development of a simple small foam airframe (Techpod, etc) fitted out with CanberraUAV electronics. Test and develop range, duration stats
Ground Equipment
Lead: Chris, Matt
  • Develop a compact catapult/launch system capable of rapid deployment in remote locations as a possible solution to absence of runway. Suitable for 4-10kg airframes
  • Develop capture mechanism/procedure for recovering airframe in remote locations to minimise damage to airframe e.g. chutes, net etc
  • Improve transportability and readiness of our equipment to allow for short notice deployments when interesting opportunities arise. Know the capabilities and limits of our airframes and suitability for the particular scenario
  • Fitting out the Ground Control Van in a better way, based on our OBC 2014 experiences
  • Develop a ruggedised mini Ground Control Station (pelican case) to enable small footprint operations
Running a mini-OBC
  • Research the feasibility of running a small scale competition/challenge with the objective of finding multiple large and small objects in a given area
  • Running a “Drone Day Out” in conjunction with mini-OBC, to showcase technologies and provide information to the interested public
Radio data link R&D
Lead: Tridge, Stephen
  • Look at using 915-928 MHz ISM radios for high-datarate datalinks, as they give better range
  • Antenna Tracker improvements (depends on radio used)
  • Develop a 3G/4G solution for situations where it is appropriate
  • Look at the feasibility of a satellite data link
  • Enhanced link aggregation and failover
  • Investigate 2.4 GHz Ubqiuti radios if the 900 MHz radios don’t work out
  • Main goal is a long range / “high” bandwidth radio that can fit on small aircraft (ie. Skywalker)
Safety Management System
Lead: Chris, Jono, James
  • Develop and implement a mature safety system for CanberraUAV’s operations
  • Create checklists, procedures for each position. Includes abort modes and airframe/engine hours/battery cycle tracking
  • Create an occurrence form to track and identify hazards, incidents and accident
  • Try to continuously improve CanberraUAV’s safety by performing ad-hoc safety management activities.
  • Develop a safety management system for CanberraUAV
  • After 12 months, the goal would be to transition to the SMS, which would be ongoing and more mature way to continuously improve safety (compared to ad-hoc safety management)
Documentation and Admin
Lead: Stephen
  • Update documentation for the cuav and MAVProxy software packages
  • Investigate more effective ways to manage and publish documentation
  • General updates of the CanberraUAV website and “admin” github repository
  • Collating documentation into a “how to” guide for S&R organisations to quickly replicate our setup. Include data on different systems (ie. compare cameras)
  • Gain UAV Operators Certificate to enable non-hobbyist operations
  • Document a “how to” guide to enable prospective users to build our system step by step (suggest video/series of videos on youtube). This would include ground station setup, telemetry links, MAVProxy.
Collaboration
  • More work with universities, high schools and SAR organisations
  • Work with landcare or similar groups for environment monitoring type tasks
  • Build relationships with emergency services/SAR organisations (ie SES)
Comment by Jacko on November 4, 2014 at 9:04pm
I would add you to our UAV operators certificate.
The rules are very strict, though actually very sensible/safety conscious. Are you hoping to do beyond visual line of sight? Let me know.
Comment by Justin Stiltner on November 4, 2014 at 9:27pm
Splenkingforth, if your comment was directed toward me I am in the united states and do not fly beyond LOS. But thanks for the offer!
Comment by Jacko on November 4, 2014 at 9:35pm
That was for Stephen in fact re: Documentation and Admin above. I'm in Australia.
Comment by Stephen Dade on November 5, 2014 at 12:17am
Splenkingforth - Not sure at this stage.
Justin - we have a mailing list at http://www.canberrauav.org.au/mailman/listinfo/canberrauav. It would be worth posting your ideas there so our whole team can see it.
Comment by Jacko on November 5, 2014 at 1:36am
OK, well I'm happy to contribute the documentation for a CASA certification.
Comment by Ned Stojadinovic on November 12, 2014 at 3:27am
Hi Stephen,
As luck would have it, I moved from Canberra just as I heard of your group! I think however that I can help you with designing and building the sort airframe and launch/recovery hardware that you'll be needing. Please feel free to drop me a line.
Comment
