  • and trying to pass it off as an engineered product!
  • hey Jack, This shows that they actually did some research on resonance! Instead of building monkey-see monkey-do in the garage out back!  Or trying to mistakenly rely fully on software for low-pass-filtering.
    Always leading the way Jack! Also interesting to see the GPS moved as far from noise as possible with a ferrite bead. Not just stuffed in between the speed controllers like the Karma.
  • Interesting how the IMU has evolved from being randomly scattered on the mane board to being encapsulated in a very large, weighted, shock dampered enclosure, connected by a very long ribbon cable to reduce coupling.  It matches what some guys discovered years ago.
    3702326096?profile=original
    3702326125?profile=original
  • Very impressive system engineering and design.
  • 3702325775?profile=originalparrot bebop 2
