For those interested in using their multicopters to carry heavy objects you might be interested in the test that I performed today with Assistant Professor Nagatani-san of Tohoku university in Japan and Izu-san of EnRoute (a company that specialises mostly in Radio Controlled vehicles here in Japan and China).
The goal for later this year is to carry a rover to the top of Mt Asama (a volcano that errupts from time to time) and drop it in mostly as a proof of concept that it can be done.
Today was our first attempt at dropping one of the university's semi-autonomous rovers (2.5kg) from an ArduCopter equipped Zion Pro hexacopter (4.0kg not including the rover).
During the first try the copter was under manual control (stabilize mode) and the servo to drop the rover was activated by the tx/rx's channel 8 switch. I was the pilot and although we were all fully expecting the copter to climb I was still surprised by the speed of the leap into the air and I couldn't keep the throttle low enough without cutting the engines completely. You can see the disasterous result 44 seconds in.
After lunch and fixing the hexa the 2nd (1:02) and 3rd tests (1:11) went much better with lower weights (300g and 1kg) and this time using Alt-Hold.
The final test (1:24) was back again with the rover but this time using alt-hold and you can see how much better the new 2.9.1 Alt-Hold is than a human pilot (or at least this human pilot!) with the copter only climbing about 10cm or so.
So the moral of the story is sometimes it's best to trust the autopilot.
wow, thanks for including the manual mode crash, it really show how the auto pilot react to that big weight / thrust change. again good job on the code guys!
Nice test Randy! This is something I have been interested in doing. That is surprising how quickly it shot up. Wouldn't be a problem if not for the ceiling! And it is a great demonstration of how good Alt_Hold is!
Do you have any plan to retrieve the rover after?
If you hadn't heard of it yet, check out the OpenGrab project. It's a magnetic system, would make for a simple release, and may allow you to retrieve too.
Love it. Third time's the charm!
Awesome Randy! Sam and I have been meaning to do something similar for a while now but can never get to it. Keep it up!
Comment by Peter Meister on February 11, 2013 at 12:59pm Awesome Randy, thanks for sharing this. It's neat to see the difference in manual vs. stabilize with the drop!
Comment by Jiro Hattori on February 11, 2013 at 3:14pm You did it!
Congratulations for great Alt_Hold software, as usual.
Want to see actual testing very soon.
BTW, your testing took place indoor.
Is it relies upon ultra sound sonar to detecting altitude (distance really)?
Comment by Jack Crossfire on February 11, 2013 at 5:53pm It needs to be lowered on cables & you need a mohawk.
@Robert,
No hard plans yet to try and get the rover back although it's been discussed. I'll point those guys at the open grab project.
@Jiro,
no sonar on that rig. Just using the regular 2.9.1 alt-hold which is inertial nav + baro.
@Jack,
Yes, a cable would be ideal. then the release could be done manually (or it would become even easier for the autopilot). Sadly my hair options have become extremely limited. :-).
Comment by Richard Boyhan on February 12, 2013 at 8:53am
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.314 members
4 members
1292 members
684 members
110 members
Powered by
