DIY Drones
Chris Anderson
FAQ: What's the difference between a gyro and an accelerometer? Do I need both?
[Marc Ramsey gave a fantastically clear and concise answer to a question that's asked here every week, so I'm going to reprint it here with some slight edits as a FAQ that we can link to from the front page.]
An accelerometer measures acceleration. A 3-axis accelerometer will tell you the orientation of a stationary platform relative to earth's surface, once that platform starts moving, however, things get more complicated. If the platform is in free-fall, it will show zero acceleration. If it is accelerating in a particular direction, that acceleration will simply be added to whatever acceleration is being provided by gravity, and you will not be able to distinguish. A 3-axis accelerometer in an aircraft in a properly coordinated turn with a 60 degree angle of bank, for instance, will show 2 G "vertical" acceleration in the aircraft, despite the fact that the aircraft is tilted 60 degrees relative to the horizon. So, accelerometers alone can't be used to keep in an aircraft in a particular orientation.
A gyro measures rate of rotation around a particular axis. If a gyro is used to measure the rate of rotation around the aircraft roll axis, it will measure a non-zero value as long as the aircraft is rolling, but measure zero if the roll stops. So, a roll gyro in an aircraft in a coordinated turn with a 60 degree bank will be measure a rate of zero, same as an aircraft flying straight and level. You can approximate the current roll angle by integrating the roll rate over time, but you can't do so without some error creeping in. Just to make life more interesting, gyros drift with time, so additional error will accumulate over a period of minutes or even seconds, and eventually, you'll have a totally inaccurate idea of your current roll angle relative to the horizon. So, gyros alone can't be used to keep in an aircraft in a particular orientation.
So, in a nutshell: Accelerometers are right in the long term but wrong (noisy) in the short term. Gyros are right in the short term but wrong (drifiting) in the long term. You need both--each to calibrate the other--to be right all the time.
But even that only works in for pitch and roll. For yaw, which is orthogonal to gravity, the accelerometers can't help you, so you need something else to correct your drifting yaw gyro. That's either magnetometers (electronic compasses, which are vulnerable to magnetic interference and intertial forces) or GPS.
GPS has a relatively slow update rate (1 to 10 Hz) and is subject to short term errors. It is possible to use GPS alone to keep a very stable and slow flying airframe on a particular ground track on a calm day.
An inertial measurement unit (IMU) combines (fuses) information from two or more sensors, such as gyros, accelerometers, magnetometer, and/or GPS, to determine orientation and velocity vector relative to the earth. The computations are fairly complex, and special filtering is often required to eliminate the measurement noise these silicon devices are subject to, so a "low cost" off-the-shelf IMU with decent specs can easily cost $1000 to $5000 US.
Infra-red horizon sensing "copilots" are inexpensive and work fairly well as long as they have a clear view of the horizon. Unfortunately, mountains, clouds, haze, buildings, etc., will confuse them. [Chris here: I think IR stabalization is more effective than people give it credit for, and is actually rarely confused in standard usage. Both Paparazzi and AttoPilot are built on it, and they work great. See this interview for more.]
In the end, the techniques used to stabilize a UAV will be very much dependent on the intended use, budget, and how comfortable one might be working with sensor fusion, Kalman filters, etc.
Borgel Comment by Borgel on July 10, 2008 at 12:02am
Do you know of any good sources of information on fusing the data from an accelerometer with that of a gyro?
Chris Anderson Comment by Chris Anderson on July 10, 2008 at 12:05am
Borgel,
Google "Kalman filter". That's the usual method.
Caleb Chamberlain Comment by Caleb Chamberlain on August 1, 2009 at 9:08am
For someone without a controls background, a simple fixed-gain observer might be easier to understand and implement; and, it should work just fine. Besides, a Kalman Filter is only optimal when noise can be modeled as a Stochastic process, which isn't always the case (I think it is usually true with gyros, but not with accels, because of extra body accelerations).
Shakeel Mahmood Comment by Shakeel Mahmood on September 11, 2009 at 5:27pm
Today i was preparing my lecture so i find my problem solution
Its outstanding effort to answer question. i lke it
Have fun
Comment
© 2010   Created by Chris Anderson
Badges  |  Report an Issue  |  Privacy  |  Terms of Service
Sign in to chat!
