Posted by Jason Short on December 18, 2009 at 9:00pm
I finally had some quality time with the Ardupilot Airframe Tester in the air and would like to report, after a few bug fixes and tweaking, I finally have a nice solution.Why this matters and why you should fly it:- It will help you set up your plane properly and give you vital debugging information.- It will help you adjust your stabilization gains- It is a very nice flight stabilizer- It will let you test your Autopilot setup (more on this below)You can read this post to learn about the debugging aspects.What I really wanted to explain is the new Fly-By-Wire mode. It essentially lets you input the relative waypoint location in space, and the plane will try to go there. Now, other than being fun, it is really helpful for debugging and adjusting your gain settings.The new FBW input is proportional and controlled with your radio:Hard right = waypoint is 35° to the right; centered = waypoint is dead ahead; left = -35°Hard up means the waypoint is below you (hey, you can reverse that if you want.) Centered means the waypoint is at the same altitude.While in FBW, the airspeed controller will try and maintain a constant airspeed.Here is the last beta. After this the tester will be final and appear in the download section.Ardupilot_25_Airframe_test_beta4.zipA note about radios - In the header file you can specify radios. Futaba Faast radios can be scanned at 50hz and others at only 25hz. This has to do with how they setup the signals. So there is an option in the header file to use Fubata or other radios. Default is "other." (Spectrum's won't work with the Futaba setting. You need to specify 'other')The events.pde file contains the code for managing your radio's 3 position switch. Instructions are in there as well.The full version of 2.5 should be right around the corner.Jason
Just kidding about the Australia bit. You should be OK, but I've not flown it south of the equator ;)
Please use the Debug mode to make sure everything is working properly with your waypoints.
OOOps. Had I read the thread again and looked closer at the header file in the Ardupilot_25 the answer was right there. Thanks though for your quick reply.
Yes I have been following it closely. I'm using TortoiseSVN extention to the Windows kernel to do checkouts and updates. It (TortioseSVN) works fine on both XP and Windows 7. It is a full SVN suite. I have the code for both Ardupilot_25 and Ardupilot_25_tester. I'm in the process of using Ardupilot_25_tester to set up my Easystar. Just finishing up the install and should be able to start using it this weekend to ground test and get my header file right. Might be able to fly it if the trade winds let up. It's windy this time of the year in Panama', RP.
Hello jasonshort . What is the default PWM pulse train and which is the PWM pulses needed for Doug? (define radio_type 0 and 1) found in your test_header_25.h
I'm using Futaba Fasst R6008HS / T10CAP / TM-10 combination. I remember the discussion but am unable to find it.
Hi Scott, Sorry for the late reply. I had a client in town and a big deadline at work.
I've been working on some new code for the radio input that will allow full radio input during autopilot and I could use some help testing it.
The big issue has always been accuracy vs hardware interrupts vs serial input. If your not familiar with these things be thankful... Anyway I think I have some code that will allow the reading of the radio and reading of the serial input at the same time. I had to heavily filter the input of the radio to do it. (as well as some other tricks) But it should be very fly-able. If this code works out, I can remove all of the current 2.5 workarounds that have been giving me so much trouble.
I will have a flyable version of 2.5 for you tomorrow so you can fly it Sunday if you like. Until then, try this new code out. Be sure to plug in your GPS unit. Don't worry about the lack of nav, the GPS is still outputting serial, which is being read by the Arduino libraries in the Ardupilot. This input is what causes the trouble. Note the behavior of the servos with GPS connected and without. Let me know your results. Are the servos smooth or are they jittery? Can you tell any difference with GPS connected?
I've also added in the Remove Before Fly plug code. This is for in air restarts or reboots. The previous code was a bit unsafe as it over-ridded the failsafe at startup. This code will check for the RBF jumper as required just like the full version.
Are you looking at the code on the Svn?
Ardupilot_25_Airframe_test_beta_6.zip
1
2
3
4
5
of 6 Next
