I went to my local Hobby Shop and they introduced me to the Tactic radios and I like the form and price. I have had an APM 2.6 for some time and thought why not get it going. when it came tome to set up the switch to control the flight modes i ran into some issues. I could not find a good source of information to set my system up. It looked like I may have made a misguided choice in radios as hardly any in the forums were using the Tactics let alone the TTX850. I found a few articles that kind helped but it meant me using up two RC channels to get the mixing I was looking for. I found some help on the rcgroups site that helped. I came across an article on the DIYDrones forums that seem to get me started. I loosely followed the Specrtum DX8 2 switch mix from DIYDrones . Below is what I came up with and will allow you to use just one channel and mix two switches (one 2 position and one 3 position) to get all six flight modes on a Tactic TTX850.
Here is my set up:
CH 6 >Reversed >Travel 85% 85%
CH6 assigned to SW H (Offset 0%, Speed 100%)
Mix 1: CH6 -> CH6
Rate L: +0%
R: +0%
Offset: +0%
CTRL: SW G 0 Pos (L(1), M(0), H(0))
Mix 2: CH6 -> CH6
Rate L: -53%
R: -59%
Offset: +0%
CTRL: SW G 1 Pos (L(0), M(2), H(0))
Mix 3: CH6 -> CH6
Rate L: -80%
R: -80%
Offset: +0%
CTRL: SW G 2 Pos (L(0), M(0), H(2))
This will give you the following Flight Modes (FM). This setup allows you to cycle through the flight modes is a sequential switch order with both switches starting at the "0" position. FM 2 and 3 are entered by flipping SW G (3 Position Switch) to position 1 and 2 respectively. To continue down the FMs you flip SW H (2 Position Switch) to position "1" and that will enter FM 4. For FM 5 flip SW G to position "1". When SW G is flipped to position "0" it will enter FM 6.
Switch 1-Position/ Switch 2 -Position = Flight Mode
H-0/G-0 = FM 1
H-0/G-1 = FM 2
H-0/G-2 = FM 3
H-1/G-2 = FM 4
H-1/G-1 = FM 5
H-1/G-0 = FM 6
Hi Jay,
I have and have used the PPM conversion board several times.
It is really not a good solution, they heat up use too much current and are unreliable.
A much better solution is one of the PPM compatible receivers, such as are made by Fly Sky, FRSky and Orange.
They actually make PPM compatible receivers to work with transmitters other than their own and for the most part they have proven to be the best solution.
I use FRSky Delta 8 PPM compatible receivers with my Hitec Aurora 9 transmitter and they work flawlessly.
The Delta 8 was made by FRSky specifically to be compatible with Hitec Receivers.
Best regards,
Gary
I will get some more pic of my TX screens to better show the setup.
Gary,
You can get a PPM interface board from DIYDrone Store. I think it is $24.90.
Jay
Hi Jay,
Great setup article for the inexpensive Tactic transmitter.
It would really be useful to know if there are any PPM compatible receivers that will work with this radio so we could use it with the Pixhawk.
Best regards,
Gary
